Hum while pedal pressed, not tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by atvkid4eva, Jul 24, 2019.
  1. Jul 24, 2019 at 2:43 PM
    atvkid4eva
    atvkid4eva [OP] Member
    I have an 03’ 4x4 5spd Tacoma. The truck has what sounds identical to a tire hum while my foot is on the gas. As soon as I let off the gas the sound instantly goes away. Sounds kind of like it’s coming from the front of the truck. I don’t even have to be accelerating, I could be doing 50 left off the gas and he noise goes away. As soon as I touch the pedal again the noise is back. Tires are brand new, it is not the tires. Any ideas?
  2. Jul 24, 2019 at 3:17 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Possibly the fan clutch has failed and has the cooling fan permanently on, causing the noise you are hearing.
    cruiserguy likes this.
  3. Jul 24, 2019 at 3:17 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    To mimic that type of sound I'd guess possible exhaust leak or ignition/timing type issue.
    01x4 likes this.
  4. Jul 24, 2019 at 3:20 PM
    atvkid4eva
    This could be possible. How would I check this? When should the fan be on/off?
    I’ve made sure the exhaust is leak free. Not sure about the ignition/timing. Truck runs fine otherwise
  5. Jul 24, 2019 at 3:57 PM
    cruiserguy
    Elijah
    SEKS
    Rereading your post after seeing what xtrmwhlr wrote, fan clutch stuck engaged is plausible. That's usually described more as a roar not so much a hum. But maybe there is something going on with clutch or pulley bearing. Worth checking out though
  6. Jul 27, 2019 at 10:53 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    I got the same problem here it just started Monday or Tuesday like a bearing noise i check my fan clutch yesterday i can turn it freely i get no resistance at all just spins an went i press the pedal it wont speed up with engine .
  7. Jul 28, 2019 at 7:22 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    That is definitely a shot fan clutch.
  8. Jul 28, 2019 at 9:05 AM
    taco03Trd
    Carlos
    Riverside ca
    Yeap and maybe the fan bracket bearing is gone too ill check it .
    Thanks for the advice
