humm/whine
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Apr 18, 2009.
  1. Apr 18, 2009 at 8:15 AM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hello everyone!
    Recently my truck started humming/whining in 1st 2nd and 3rd gears when accelerating, it's pretty loud from inside the truck. loud enough that I don't hear my exhaust much(aftermarket).
    It kinda of sounds like power steering, but it's not when i'm turning, it's always, I did check my power steering fluid and it was low so i topped it up.
    oil level is good, I'm thinking transmission fluid? how do i check if that's it? I want to change the tranny fluid anyways, so i'll probably do that when I can, but what could be some other culprits?
    Mt 90 in the tranny?
    Thanks
  2. Apr 18, 2009 at 11:43 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    when you say "whine", definitely the first thing that comes to mind is power steering...
  3. Apr 18, 2009 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Oil level is low, or needs changeing. See #2.
    I have had good luck in useing Mobil 1 75-90 Synthetic. :)
  4. Apr 18, 2009 at 6:10 PM
    0wrx2
    0wrx2 Well-Known Member
    north nj / upstate ny
    '10 trd sport 4x4. dbl cab. shrt bed.
    ive been lurking around here for a while now as i plan on buying an 09 DC TRD OR in june....
    with that being said... it sounds exactly like a problem i had with my WRX. I had a whine coming from under the hood, occurred all the time regardless of steering. mine got louder as rpms increased. turned out to be a busted idler pulley bearing on my AC belt. stick a screwdriver on the pulleys one by one and put the handle of the screw driver to yer ear to diagnose the source. hope this helps!
  5. Apr 18, 2009 at 10:34 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    chris, I just changed to Mobil 1 two weeks ago. put in 5.4Litres. I checked and it's sitting perfectly full.
    From asking around, most people are saying power steering pump, and it does sound like power steering, I guess a new pump is in order
  6. Apr 18, 2009 at 10:36 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    oh NVM chris, you mean tranny oil. I'll do that first, thanks!
  7. Apr 18, 2009 at 11:06 PM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    I have the EXACT same issue, the sound gets louder when rpms increase and quieter as they decrease. The dealership tells me its my air intake, which is total BS, because I never noticed the noise till I had about 5k miles on the truck. Had it been the Intake it would have been there since day 1.
    I dont think its the tranny because it makes the noise in neutral also.
    If you figure it out, PLEASE post it!
  8. Apr 19, 2009 at 12:32 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well, I'll be doing the tranny fluid asap regardless, but I believe it's power steering, it's that sort of wine
  9. Apr 19, 2009 at 6:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could be the power steering. I just read that it happens when accelerating in gear, and most gear associated noise is from the tranny oil level being low.
