humm
Discussion in '1st Gen. Tacomas (1995-2004)' started by bryans 86, Feb 24, 2009.
  1. Mar 7, 2009 at 3:29 PM
    bryans 86
    bryans 86 [OP] Member
    nh
    01 double cab
    see i would think if the coil was bad it would cause 2 cylinders to misfire ?
  2. Mar 7, 2009 at 3:56 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    The coil that misfires, usually fires through the boot, in to the metal spark plug tube. The coil is just the small plastic part, on top. You can remove the boot from it, just like taking it off of a plug other side. It's usually not the coil that fails, essentially just the boot connected to the coil. Unfortunately, when you buy the boot from Toyota, it comes with a free, brand new coil attached to it. I pay cost plus 10% at work, and got mine for $90.00 each.
  3. Mar 11, 2009 at 4:28 PM
    bryans 86
    nh
    01 double cab
    so its still skipping ... replaced the coil changed the plugs. should i try a tps sensor ? the code is still p0306 .. so cylinder number 6 is still misfiring.
  4. Mar 11, 2009 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How do the wires look?
  5. Mar 11, 2009 at 4:31 PM
    98tacoma27
    Ben
    Not Beech Creek
    TPS shouldn't cause this. I think the cam shaft sensor would though.
  6. Mar 11, 2009 at 5:14 PM
    bryans 86
    nh
    01 double cab
    the wires look good but number 6 cylinder is the one right in the front underneath the coil pack right ?
  7. Mar 11, 2009 at 5:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looking at the engine with the passenger side on your left the cyls. are like this:
    5 6
    3 4
    1 2
  8. Mar 11, 2009 at 5:48 PM
    bryans 86
    nh
    01 double cab
    so number 6 is on the drivers side? closest to the firewall ? i guess ill try new wires tommorow
  9. Mar 11, 2009 at 5:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    I thought you replaced the wires?
  10. Mar 11, 2009 at 5:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep
    X2..
  11. Mar 11, 2009 at 5:57 PM
    bryans 86
    nh
    01 double cab
    nope i just inspected them because i thought that number 6 was on the passenger side ... this is good news hopefully the wire is just messed up .. let u guys know tommorow night
  12. Mar 11, 2009 at 5:59 PM
    98tacoma27
    Ben
    Not Beech Creek
    Buy a new set and replace them all.
  13. Mar 11, 2009 at 8:55 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ide like to know how this turns out, bc my idle has been acting up. its a little rough and rpms fluctuate and get pretty low. (almost 500rpm)
  14. Mar 13, 2009 at 11:36 AM
    bryans 86
    nh
    01 double cab
    yep so it was just a bad spark plug wire. it was firing down the outside of the spark plug and grounding out .. all fixed thanks for the help guys i still want to sell the truck thoe. just got offered a 2004 duramax diesel lifted with 37s, quad cab, 125k, some banks performance modifications for 16k...
