humming coming from front right of tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sickkspence, Jan 14, 2017.
  1. Jan 14, 2017 at 4:12 PM
    Sickkspence
    Sickkspence [OP] New Member
    Spencer
    2012 TRD sport Tacoma 4x4
    I have a hum that is coming from the front ride side of my truck I don't believe it's my tires because it isn't constant. It happens on random occasion, the truck also pulls to the right slightly when the hum isn't there. I've seen some videos on wheel bearing and I don't think it's that because it's not all the time. I've looked for rubbing and can't see anything that may be causing the issue
  2. Jan 14, 2017 at 4:17 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Jack up the truck and check for play.
    Sounds like a wheel bearing to me.
    loginfailed likes this.
  3. Jan 14, 2017 at 4:35 PM
    Sickkspence
    Spencer
    Thanks I'll give it a go on my days off.
  4. Jan 14, 2017 at 9:40 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    If it gets worse on right turns and stops on left turns, its probably a wheel bearing.
  5. Jan 15, 2017 at 1:12 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I had the same thing. Was intermittent and as time went on it would occur longer. Was never constant though. I went with BamaToy's wheel bearings kit and haven't had an issue since. He's in the 2nd gen market place. I'd recommend picking up his kit if it's your bearings.
  6. Jan 15, 2017 at 1:22 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    My bet is a wheel bearing, but also try and see if it is there in 4WD or not. You can engage 4WD on pavement as long as you don't make any significant turns.
