Humming from wheel well after ECGS bushing install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mwhres145, Feb 23, 2023.
  1. Feb 23, 2023 at 1:14 PM
    Mwhres145
    Mwhres145 [OP] Well-Known Member
    2015 Tacoma
    Hello,
    Last summer installed an ECGS clamshell bushing due to vibes after an OME lift. Solved the problem. Fast forward 4-6 month later and now I have a humming noise coming from driver side wheel well area only in 4 high. Mostly only hear it when driving btw 25-35 mph and most noticeable on acceleration. Followed all instructions/ torque specs when I did the ECGs install.
    Thoughts on this?
  2. Feb 23, 2023 at 1:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The CV is always turning, even in 2WD.
    If it only happens in 4WD, I wouldn’t expect it to be the bushing.
    You have 2 options, pull the CV and inspect the bushing.
    Or drain the front differential fluid and look for metallic particles in the fluid.
    Before I did any of that, I would check the fluid level.
    It’s really easy to do. I had to add about 1/5 of a quart after I did my bushing.
    I drove it a couple weeks and checked, topped it off and it’s been good since.
    (Well…..kind of. But that’s a different story.)
    Mwhres145[OP] likes this.
  3. Feb 23, 2023 at 5:53 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get it up on stands, spin the wheels up to speed and listen with a stethoscope
