Humming Growling sound- wheel bearing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Greatdane01, Feb 5, 2024.
  1. Feb 5, 2024 at 11:53 AM
    Greatdane01
    Greatdane01 [OP] Well-Known Member
    3rd Gen TRD Sport Tacoma
    3” lift, XD Wheels, BFG Tires, GT momentum cold air intake
    2020 Tacoma 2wd w 100k miles. I started getting a low growling humming sound. It’s not the engine because the sound continues if I shift to neutral and coast or turn off motor while moving in neutral. I’m thinking it might be front wheel bearings?? Because the sound almost vanishes in a turn. The hum gets louder and higher toned with speed, at any speed. Kinda sounds like a small airplane motor flying by. Possibly rear Differential? Open to suggestions on isolating this.
  2. Feb 5, 2024 at 12:03 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Probably one of the wheel bearings. Could be front or rear.
    Greatdane01[OP] likes this.
  3. Feb 5, 2024 at 12:11 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    possibly brake wear indicators
  4. Feb 5, 2024 at 12:21 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like a wheel bearing to me.
    wilcam47 and Greatdane01[OP] like this.
  5. Feb 5, 2024 at 12:57 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Center bearing prop-shaft support bearing going bad will do that.
  6. Feb 5, 2024 at 2:41 PM
    DMel
    DMel Well-Known Member
    2020 TRD OR Cement
    Looks like a faulty bearing, I had that problem couple months ago. Ended up waiting 1.5 months for bearing to arrive.
  7. Feb 5, 2024 at 4:58 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Did you check the tires? Sometimes the tires can cup and create a wheel bearing-like noise.
  8. Feb 5, 2024 at 5:18 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Under normal circumstances it's a little early, but X3 for the wheel bearing, in all likelihood, on the front.
    If it's worn enough, you can jack up the front end, grab the tire and feel the up / down play.
    Once confirmed, it's an easy fix. Grab a a pair of hub assemblies, 200lb tq wrench and knock them both out at once.
  9. Feb 6, 2024 at 2:35 PM
    ginch
    ginch Member
    Derek
    2017 TRD sport Quadcab shorty
    Was dealing with this issue on my 2017. My wife usually drives the taco as its her daily! I drove it to get an oil change and realized the thing was humming like crazy. It had just over 100.000 km's (60.000 miles) on it with 4 year old KO2's. I assumed the tires were causing the noise so I put on some new Wildpeak AT3W's. Well that didn't fix the issue! Turned out it was the passenger side rear wheel bearing! Took over a month to get the factory wheel bearing! Crazy! Anyways, installed and the noise was gone!
  10. Feb 6, 2024 at 3:12 PM
    Greatdane01
  11. Feb 6, 2024 at 3:15 PM
    Greatdane01
    Did you replace them yourself? I did my 2011 myself and it wasn’t that challenging. The dealer here has the parts in stock @ $340 each! Dannnngggg I might just go after market if that’s what OEM costs.
  12. Feb 6, 2024 at 3:16 PM
    BLtheP
    Plano, TX
    Rears aren’t hard but not very DIY friendly since you need the specific Toyota wheel bearing puller and a press. Well, I guess you could cut the old bearing off with a whole bunch of cutting in lieu of the puller. But that would suck.
    But if you did a 2011 then you already know. And yeah, sadly the OEMs are high priced but they are the best option for reliability/longevity.
  13. Feb 6, 2024 at 3:37 PM
    Greatdane01
    UPDATE- I jacked up the front end. Drivers side has 1/4” of sloppy play when I pull the tire a my hands. That one’s shot. The passenger front isn’t sloppy but it has a sort of grinding sound and doesn’t spin very freely. Guess I’ll do them both. Thanks all!
    wilcam47, Old goat1914 and jmneill like this.
  14. Feb 16, 2024 at 12:41 PM
    FREDICVSMAXIMVS
    FREDICVSMAXIMVS New Member
    Fred
    2011 Tacoma, 4x4 V6, double cab long bed Speedway Blue
    I'm facing the same issue on my 2011 4x4 double cab. I haven't had a chance to jack it up yet to confirm that's what's going on, but from all that I've read it seems extremely likely. That said? does anyone have an opinion on this part from Napa? It's spendy (especially for two) but I want something that will last...
  15. Feb 16, 2024 at 12:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Get this one since it uses a Koyo bearing. If you need two, there's a listing on his profile for the pair and it knocks off a few bucks. I used to run these on my truck, which saw tons of abuse.
    https://www.ebay.com/itm/151286082490
    https://www.ebay.com/itm/161936484299?itmmeta=01HPSV279BNYMX9ECGXEYZAJ63
  16. Feb 16, 2024 at 12:55 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Sloppy left to right or up and down? Left to right can be attributed to the tie rod. If you grab the tire at 12 and 6 o clock and there is play, then it's wheel bearing.
    Other symptoms of a bad front bearing are squishy brakes, or if the grinding/humming goes away while turning. For example, your driver-side bearing is making noise. On a sweeping right turn, there is more side load on the driver bearing, and takes away the play and gets rid of the noise. Just a few examples for future readers of this thread.
  17. Feb 16, 2024 at 1:02 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I don't see brand of bearing used on those, so I'd keep looking for something with Koyo or another well known brand. NSK?
    EDIT: I used these guys:
    https://www.yotabearingsandhubs.com...-koyo-front-wheel-hub-bearing-assembly-1-pair
  18. Feb 16, 2024 at 3:09 PM
    Greatdane01
    Not spendy compared to the dealer who wanted $790 per wheel for parts plus $400 install per side, plus tax. $2800? I got a set on parts geek for $275 total, installed in 30mins per side. I can replace them ten times for the cost from the dealer.
  19. Feb 16, 2024 at 3:12 PM
    jmneill
    SE
    I'm running on the generics @ $49 bucks a pop. lol
    We'll see how that goes.. :anonymous:
    Quality actually "looked" good, believe it or not.
    wilcam47 likes this.
  20. Feb 16, 2024 at 3:53 PM
    FREDICVSMAXIMVS
    Fred
    Hehehe. I might swing by NAPA anyway and take a look; I'm paranoid about my wheel falling off and I was hoping to fix it this weekend
