humming in front end?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BR63600, Oct 15, 2012.
  1. Oct 15, 2012 at 4:22 AM
    BR63600
    BR63600 [OP] Member
    brian
    oswego, ny
    06 Taco 4x4
    3" lift (Bilstein shocks/struts, ome coils, skyjacker leafs) SR8 - SCS wheels
    2006 Taco 4x4. Bought my Taco last November. After a few month I started hearing a hum come from the drivers side front end. First thought was a bad wheel bearing. The sound got louder over a few months. Turning to the right it was obvious and turning the left it went away. So I had the drivers side bearing changed. My mechanic buddy said the bear had good wear on it.
    But the humming has not got away. It's still active when turning to the right and goes away when stealing to the left. I have a 3" block lift on the truck that was there when i purchased it. And now has some front end chamber. My buddy thinks it had something to do with the chamber.
    Does anyone have any ideas or suggestions what the humming is or could be from?
  2. Oct 15, 2012 at 4:29 AM
    Namyo
    Namyo -
    Does it feel like a hummer? :laugh:
  3. Oct 15, 2012 at 4:30 AM
    Namyo
    Namyo -
    I mean can you feel it? :facepalm:
    Could be plastic in the wind? Maybe the trimmed plastic in front of the tire :notsure:
  4. Oct 15, 2012 at 4:46 AM
    BR63600
    BR63600 [OP] Member
    brian
    oswego, ny
    06 Taco 4x4
    No heavy vibration if thats what you mean. Mostly just hear it. It annoying and if its something that gonna be damaging later on I wanna fix it asap.
    Don't think its the plastic. It's gotten louder over time. So I'm wondering what it would from.
  5. Oct 15, 2012 at 5:00 AM
    Namyo
    Namyo -
    That's the only thing I can think of, something fapping in the wind :notsure:
    I had a suspension squeak for the longest time, turned out to be my bumper rubbing on the headlight support :cool:
  6. Oct 15, 2012 at 5:14 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    tires mabye....
  7. Oct 15, 2012 at 5:23 AM
    BR63600
    BR63600 [OP] Member
    brian
    oswego, ny
    06 Taco 4x4
    Tires is all I could think of. Just seems odd that it only hums when steering right.
  8. Oct 15, 2012 at 5:30 AM
    Namyo
    Namyo -
    I was thinking this thing...
    That little tit gets trimmed, sometimes just folded up and sometimes chopped off, could be the edge buzzing in the wind. Does it happen when going slow or just at speed?
  9. Oct 15, 2012 at 5:49 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    your problem sounds like my truck. same hum, but when i turn my wheel to the right it goes away. im going to get the wheels balanced and the truck aligned and see if that helps. i thought it was my wheel bearing too when i first heard the hum. idk what it is, but we will figure it out. the only thing different you have on your truck is a lift. :notsure:
  10. Oct 15, 2012 at 6:03 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Did you check passenger side bearing? if driver side had wear then passenger side is probably in not very good shape. Pass side seems to wear faster.
  11. Oct 15, 2012 at 6:35 AM
    BR63600
    BR63600 [OP] Member
    brian
    oswego, ny
    06 Taco 4x4
    Namyo, that plastic piece has already been removed by the previous owner. Prolly do to the tire size.
    I jacked up the pass side of the truck to do a 12/6 & 9/3 shake test for the bearing. No movement. I couod be wrong but I'm convinced its not the pass bearing. I'll prolly have it changed out soon anyway because the drivers said was done.
    My tires rub on the frame when in reverse and cutting hard, but thats it. No driving issues. Planned on getting spidertrax spacers to fix that issue. Just want to make the are strong enough to with stand some light trailing.
  12. Oct 15, 2012 at 9:08 AM
    BlueT
    NorthEast
    keep in ming wheel shake is not always best indication if wheel bearing is lose. Old trucks usually have brake pads that hold disk enough to not allow wheel to move when testing. Also you could have dry wheel bearing not necessary one that already have enough play. What you describe sounds like wheel bearing I would do careful examination
  13. Oct 15, 2012 at 10:20 AM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    both my front wheel bearings were tight when I grabbed the tires and tried to move them, both had water get in the outer bearing, grease diminished, dried out rusted and fucked from heat. I even thought they were fine when I got them off the truck and took them to a buddys who has the press. they seemed fime when rotated by hand but without the weigt of the truck on them u cant tell. Once they exploded in the pressing process u could clearly see the wear.
  14. Oct 15, 2012 at 10:42 AM
    brbeel
    brbeel Member
    Brian
    Albuquerque
    06 Sport Long Bed 4X4
    I had the exact same problem with my 06, except the sound would go away when turning right. I replaced both bearings and the hum went away.
  15. Oct 15, 2012 at 11:44 AM
    BR63600
    BR63600 [OP] Member
    brian
    oswego, ny
    06 Taco 4x4
    Think ill just pick up the pass bearing and change it out and see what happens.136K mi. on the truck. Changing both bearings will only help things out.
    Thanks for all the input guys. If the 2nd bearing change out doesn't work you'll know haha.
  16. Oct 16, 2012 at 12:21 PM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Eibach Springs with Billstien 5100's - Full Katzkin Leather - Back Flip Roll-X bed cover - Custom Projector/Dual Halo Headlights by ambiguous - Eagle Eye LED tail lights - LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Rear AAL TSB - 4 Tie Down Mod - Pop N Lock - Running Boards - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Keep us updated, I would like to hear the solution.
    Welcome to TW. Again.
  17. Oct 16, 2012 at 6:04 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
  18. Apr 16, 2013 at 3:28 PM
    Bluewater
    Bluewater Big Bruddah
    Kailua-Kona Hawaii
    Speedway blue 06 TRD Sport 4x4, 4dr, Long bed
    K&N Replacement filter, 3" leveling kit, Chrome side steps. Mud flaps removed.
    Change both front wheel bearings an while you're at it the spindle bearing and say goodbye to annoying noise..
  19. Apr 16, 2013 at 3:48 PM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill, Westin light bar, LED lights
    Maybe your truck just forgot the words?
  20. Dec 28, 2013 at 7:15 AM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    So if this humming is coming primarily from the driver's side, what could the cause be?
