Humming noise front diff or wheel bearing?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Noah Anderson, Sep 30, 2021.
  1. Sep 30, 2021 at 8:09 PM
    Noah Anderson
    Noah Anderson [OP] Member
    Noah
    2002 Toyota Tacoma 4x4
    Bilstein 5100, Toyotec 3 inch lift coils, spc adjustable upper control arms, 1 inch blocks in the back
    Got a first gen Tacoma been having a humming noise coming from front of the truck hate to think it’s the front differential but I’m starting to get convinced I feel a vibration in the floor and it’s most noticeable at 35-50 mph after that it dies down. Any thoughts?
  2. Sep 30, 2021 at 8:20 PM
    Noah Anderson
    Noah
    There is no play in the bearings
  3. Oct 1, 2021 at 8:05 PM
    wesb1023
    wesb1023 Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    Most likely wheel bearings. Try to find a smooth steady paved portion of road, and while you hear the noise turn the steering wheel left and right. This puts a side load on your wheel bearings. If your noise goes away, changes tones, or gets worse while turning, it’s most likely a wheel bearing.
    If there is no change in the noise at all, shift into 4x4 and listen for a change in sound. If you have an ADD differential in the front, the spider gears are spinning in the front differential while it’s in 2wd, shift to 4x4 and the spider gears stop spinning, and the ring and pinion start spinning.
    It could also be tire noise, they normally change tones dramatically when going from smooth asphalt to rough asphalt, but that all depends on what tires you’re running. If you’re running MT’s you can expect road noise. Look for abnormal tire wear.
    Those are all the things that come to my mind, without any more information.
  4. Oct 1, 2021 at 9:33 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Check your carrier bearing or u-joints as the speed you stated is indicative of those items going bad.
    I thought my left side wheel bearing was bad, turns out it was my right side.
    Noise plays tricks with you with vehicles.
  5. Oct 1, 2021 at 10:39 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I would rotate my tires first and see if that changes anything. Also check front and rear diff fluid.
