humming noise front end cant figure out!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chopper, Jul 14, 2010.
  1. Jul 14, 2010 at 8:02 PM
    chopper
    chopper [OP] ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    Humming noise front end of my 05 taco can't figure it out
  2. Jul 14, 2010 at 8:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!
    give us a lil background about the truck....stock height...non stock??? what?
  3. Jul 15, 2010 at 6:59 AM
    chopper
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    Humming noise in front end
  4. Jul 15, 2010 at 7:00 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Probably hit a humming bird. hur hur hur
    But seriously... any shaking? Or just the hum?
  5. Jul 15, 2010 at 7:06 AM
    chopper
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    05 tacoma rev cab stock lift 4 banged 5 speed 254/75/16 tires no modes yet! I plan on getting a new double cab trd offroad and keep my reg cab and build it up.
  6. Jul 15, 2010 at 7:15 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    And... any particular tune?
  7. Jul 15, 2010 at 7:17 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    classic wheel bearing sound is humming. how many miles on your 05
  8. Jul 15, 2010 at 7:23 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Could be your wheel bearings.
  9. Jul 15, 2010 at 12:08 PM
    chopper
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    Checked wheel bearings there good no shaking just a hummmmmmmmmmmmmmmmm
  10. Jul 15, 2010 at 7:48 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    is it when you are running your a/c? My truck humms when the compressor kicks on.
  11. Jul 21, 2010 at 2:46 PM
    jpcarlson
    jpcarlson New Member
    Dayton
    On my 06 Tacoma I just had to replace bearings and Hub housing (800 bones), it hummed and drove like it was stuck in 4wd.
  12. Jul 29, 2010 at 5:00 AM
    rhag1128
    rhag1128 Member
    New England
    05 TRD Sport
    Eclipse indash HU
    My stock 05 4dr sport started humming this week - just rolled 100k mi.
    sounds almost like steel belts on the road. Most noticeable above 40mph. Sometimes when backing out of a parking space it had a slight stiffness like it was in 4wd but went away after straightening the wheel. I will have to look into the front bearings issue. no shaking or wandering on the road just a speed related hum.
  13. Sep 2, 2010 at 7:16 PM
    rhag1128
    rhag1128 Member
    New England
    05 TRD Sport
    Eclipse indash HU
    So I finally picked up a 36mm socket and took off the bearing assembly. I am moving forward with this since the hum goes away when I turn right even just a bend in the road it goes away. There was no play in the wheel 12 and 6 as well as 3 and 9. when I took it out there was a white spring ring that I believe seats the bearing to the inner oil seal but Im not sure since there were two in there. One was still seated and another was between the bearing race and knuckle. Is there supposed to be 1 or 2 of these things in there - can anyone shed some light on this???????? I looks like the outer oil seal tore/separated from the cv too. Picking up new bearing tomorrow with new seals hopefully I can fine someone to press them out and in.
