Humming noise in frontend
Discussion in '3rd Gen. Tacomas (2016-2023)' started by white08gt, Dec 12, 2021.
  1. Dec 12, 2021 at 7:01 PM
    white08gt
    white08gt [OP] Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    My daughter just got a 2022 4Runner SR5 Premium 4wd. Noise goes away in 4 hi, see that this has been an ongoing problem. Why has Toyota not fixed this problem and where is it coming from? Front diff or wheel bearing, hate to think a stealership mechanic having to install one. I had a 92 4Runner that the rearend went out just out of warranty around 62k miles. My 05 Tacoma had a lsd and clutches slipped on right turns. Changed fluid and added additives that would help for only about 10k miles. Rearend always got so hot you couldn't hold your hand on it. I know this is Tacoma forum but underneath they are same and I am not a member of the 4Runner forum.
  2. Dec 12, 2021 at 7:08 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    There is a 4Runner section on here.
    But to address your statement, I think we'll need a little more information. Maybe a video/audio or something. No hum noticed in our 2019 SR5 4Runner.
  3. Dec 13, 2021 at 7:45 PM
    white08gt
    Al
    Tn
    05 dbl cab 4x4 sr5
    I am not a member of the 4Runner forum, underpinnings are the same and it is a problem that has been going on since 2005. Plenty of you tube videos with the fix and a TSB for it but no recall. Should not have this to keep happening, there is an aftermarket fix. ECGS fixes the problem, guess it is the luck of the draw. Spend $46k for a new vehicle it shouldn't have 16 year old technology.
  4. Dec 13, 2021 at 8:06 PM
    RedWings44
    Michigan
    I understand that you aren't a member of the 4Runner Forum. However, there is a 4Runner section on this website.
    Like I said, I haven't experienced any such thing on my 4Runner.
    Mozart likes this.
  5. Dec 13, 2021 at 8:47 PM
    Mozart
    Mozart Well-Known Member
    Cortland NY
    2018 ACLB SR5 4x4 V6
    32” Tires, BPF Front Recovery
    New to Toyota eh?
  6. Dec 13, 2021 at 9:03 PM
    Gonks
    Gonks Well-Known Member
    OC
    SOLD 2020 White TRD Offroad 4x4
    If it is still so new I'd take it to check it under warranty, even as much as I like to wrench.
  7. Dec 14, 2021 at 12:36 AM
    dezert.taco
    dezert.taco Well-Known Member
    Nate
    Northern Nevada
    2018 Tacoma
    Why shouldn’t it have 16 year old technology? Axles are certainly much older than 16 year old technology, transmissions, engines etc all much older than 16 year old technology. If you didn’t want a vehicle with “old” technology then should of bought a Tesla.
