Humming noise on 4H on lower speeds up to ~40
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nalex, Jan 3, 2022.
  1. Jan 3, 2022 at 7:37 AM
    Nalex
    Nalex [OP] Well-Known Member
    2012 Tacoma DC TRD OffRoad
    Hi all,
    It has been a while since I used my 4x4. So I don’t know if this always been the case or my ocd is getting worse as I am getting older. I m hearing like a humming noise on 4H on lower speeds up to 40ish maybe. It will stay the same even when I put the car in neutral while rolling at low speed.
  2. Jan 3, 2022 at 7:52 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Can’t say for sure what you are hearing but it is more than likely just the forward driveline engagement below you resonating through the cab. Your front driveshaft is now spinning and bringing on a “new” vibration into the cab.
    Nalex[OP] and wi_taco like this.
  3. Jan 3, 2022 at 7:57 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is going to be some noise when 4X4 is engaged. Probably normal and you just haven't used it in a while and forgot about it. Even in neutral the front driveshaft and axle are turning, just not getting power. But then again you could have a problem. Hard to diagnose on a keyboard.
    FYI, I hope you aren't driving around on pavement in 4X4. Occasionally, and for short distances, and only in a straight line you should be OK. But it isn't intended to be used at highway speeds on hard surfaces with good traction. I can't think of any place where I need to be in 4X4 where I'd be driving over 20 mph.
    Nalex[OP], XSplicer62 and Sprig like this.
  4. Jan 3, 2022 at 8:54 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The front driveshaft doesn't spin in 2wd, only the front spider gears. The additional components that spin when you make the shift are the front ring gear, transfer case front flange and the front driveshaft. My guess is likely culprit (assuming it's not a normal hum), is a worn u-joint on the front driveshaft.
    tacotoe, Nalex[OP] and wi_taco like this.
  5. Jan 3, 2022 at 10:18 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    OP when is the last time you greased u joints on front drive shaft?
    Nalex[OP] likes this.
  6. Jan 3, 2022 at 3:17 PM
    Nalex
    FYI, I hope you aren't driving around on pavement in 4X4. Occasionally, and for short distances, and only in a straight line you should be OK. But it isn't intended to be used at highway speeds on hard surfaces with good traction. I can't think of any place where I need to be in 4X4 where I'd be driving over 20 mph.[/QUOTE]
    Usually on snow icy roads. The manual mentions up to 60 on 4H. I almost never go that fast on 4 high.
    tacotoe likes this.
  7. Jan 3, 2022 at 3:19 PM
    Nalex
    2 years ago. I was planing to do it this past summer and totally forgot.
    tacotoe likes this.
  8. Jan 3, 2022 at 3:25 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Stock height, like no lift or anything?
    Nalex[QUOTED][OP] likes this.
  9. Jan 3, 2022 at 3:48 PM
    Nalex
    Yes, the only thing non stock is the 17 inch wheels out of 4Runner.
    It sounds like the engine fan when you first turn on the truck in the morning and you have to listen carefully to hear it. Or feel it I guess :confused:
    tacotoe[QUOTED] likes this.
  10. Jan 3, 2022 at 4:20 PM
    TacoTuesday1
    FL
    60 is max speed to drive in 4H? I doubt that. I've driven faster. Highway speed limit is 65mph or greater depending on location.
    I don't see why it would have a limit
    Do you mean maximum speed to turn it on while moving?
    There are probably vehicles out there with 4x4 turned on due to weather going above 60 rather than following semi's in the slow lane with their hazards on
    Nalex[QUOTED][OP] and tacotoe like this.
  11. Jan 3, 2022 at 4:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    manual states up to 60mph TO ENGAGE 4hi.
    There is zero issue going 60+ in a straight line on dry pavement (assuming same tire size and tire wear) in 4hi.
    tacotoe and Nalex[OP] like this.
  12. Jan 3, 2022 at 4:28 PM
    Nalex
    I don’t have the manual at the moment but as far as I can remember you can engage 4H safely below 60mph and recommended not to exceed that speed. You should use 4H on wet slippery surfaces and yea you can take turns. 4L is a different story.
    tacotoe likes this.
  13. Jan 3, 2022 at 4:30 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Usually on snow icy roads. The manual mentions up to 60 on 4H. I almost never go that fast on 4 high.[/QUOTE]
    Don’t worry about MarshallR. He has a long and documented history of being afraid to use 4WD on his 4x4.
    6 gearT444E likes this.
  14. Jan 3, 2022 at 4:52 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Well, as suggested grease them universal joints, inspect them. I like doing my own maintenance like transfercase and differential fluid changes so if I seen something suspect then I know there may be an issue. This is how I discovered it may be time to do the bushing on my wife's 2nd gen. The magnet on the plug had much more fuzz on it than expected. (Hers is lifted =increased driveline/front axle cv joint stress)
    My guess is just additional normal driveline noise, which you going to have especially if snow/ice pack roads. There just going to be more noise.
  15. Jan 3, 2022 at 4:55 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    OP I have this same annoyance and thats what it is cus Ive relubed my manual hubs, taken them apart, both cv axles are fine, changed front diff oil (oil was good), greased all the driveline, ujoints are fine. I have came to rhe conclusion after 3 years that its just normal sound cus it doesnt get used daily, but 3 years later nothing has broke.
  16. Jan 3, 2022 at 5:53 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I do it all the time, just did it a week ago Sunday. The road between St Cloud and home was snow-covered and packed like ice, with blowing snow on top of it. Was able to manage a speed of 55/60 mph. You learn to stay away or slow down for the shiny spots.
  17. Jan 3, 2022 at 10:48 PM
    TacoTuesday1
    FL
    Don’t you have to engage it at least once per month to keep it in good working order/prevent the actuator from failing
    Rally drivers start out sawing a bit on the steering wheel
    to feel out the road surface to know how much available traction there is
    tacotoe likes this.
  18. Jan 4, 2022 at 9:27 AM
    wi_taco
    Adam
    SE Wisconsin
    2 years since greasing u joints?! Bruh, go grease your front two u joints ASAP (and the three on rear driveshaft while you are at it) and pray the needle bearings havent disintegrated into powder yet. Should grease them every oil change in future as preventative.
