Humming noise/Ruling out bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by h22dx, Oct 4, 2014.
  1. Oct 4, 2014 at 11:30 AM
    h22dx
    h22dx [OP] Well-Known Member
    louisville,ky
    07 trd sport
    Ok so my 07 has been making a front end humming noise for about 10 months. The reason I have let it go so long is because it only presents itself when it is below 60 degrees outside. It only does it when the engine is around 1200-1500 rpm and as soon as you give it more gas or let off it disappears?? It is driving me insane and I cant figure out what it is. I replaced the passenger wheel bearing last year so I know what that sounds like. Im thinking maybe a motor mount?? Please help guys! :confused:
  2. Oct 4, 2014 at 12:43 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Does it not do it neutral and only in gear when you give it a tiny bit of gas????
    Any possibility it could be coming from the rear??
    I'm thinking the rear differential? Or possibly a U joint???
    I'd check the Diff fluid /level for starters. Might be dirty r rend oil or pinion preload/???
  3. Oct 5, 2014 at 4:58 PM
    h22dx
    louisville,ky
    07 trd sport
    I cant do it in neutral. Its def not coming through the rear. I had the diff fluid changed out on both diffs about a year ago so that should be good. It has me puzzled!
  4. Oct 5, 2014 at 5:56 PM
    Canufixit
    New England
    Does it not do it only when you give it a tiny bit of gas???? (very light acceleration - coasting no - very light acceleration yes ??
    If So, Pull the rear drive shaft put it in 4 wheel drive and take a ride. If It's gone It's the rear diff. I had to have mine change at about 5K miles.
  5. Oct 5, 2014 at 6:11 PM
    yodatoyota
    yodatoyota Scrub
    tim
    Barrie Ont. Can
    2021 TRD OR 4x4 sb
    Empty wallet mod
    I've have something similar happing right now and was told its bearings in the front diff. or something like that. If that even makes sense....
  6. Oct 11, 2014 at 6:52 AM
    h22dx
    louisville,ky
    07 trd sport
    Its definitely not a bearing for me because it happens as soon as I hit the gas from a stop. Only when I give it the right amount of gas though. Shit is driving me nuts!
  7. Oct 11, 2014 at 8:29 AM
    Canufixit
    New England
    It's four wheel drive right?
    Take off the drive shafts one at a time and see if it goes away. When you remove the rear shaft just put it in 4x4.
  8. Oct 11, 2014 at 8:33 AM
    Canufixit
    New England
    Also, is your speedometer electronic?? Probably right?? I was just tinking on the older cars with a speedometer cable they just to get noisy sometimes.
    and for a stretch ... leaking vacuum hose??
  9. Oct 16, 2014 at 2:20 PM
    h22dx
    louisville,ky
    07 trd sport
    The sound also varies when going over bumps?? Motor mount?
  10. Oct 16, 2014 at 2:39 PM
    Canufixit
    New England
    Is It Possible the U joints have dried out and when the temp drops they start singing ??? This would fit a lot of the symptoms ...
  11. Oct 16, 2014 at 2:42 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    mud boggers.
  12. Oct 16, 2014 at 9:07 PM
    Aloe
    Aloe Well-Known Member
    05 SWB TRD Sport access cab 4x4
    URD Short throw Fisher Plow
    Idk man...had a 90 4runnner that did the same thing when it was below zero, only below zero?!?
