Humming noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bpetty9, Jan 12, 2018.
  1. Jan 12, 2018 at 8:39 PM
    Bpetty9
    Bpetty9 [OP] Member
    Blake
    2009 tacoma trd sport 4x4
    9 inches lift, 325/50/22 tires, 22x14 wheels
    i recently got this loud hum that i can hear coming from under my truck from speeds around 35-50 can’t really pin point what it is. Any ideas on that? Also i have recently gotten some popping noises when i turn my wheel or hit the gas, maybe it’s worn out suspension? Not really sure, anything helps! Thanks. P.s. i drive a 2009 tacoma 4x4
  2. Jan 12, 2018 at 8:58 PM
    Pigpen
    Dan
    Northwest Montana
    The humming is most likely your needle bearing. Common problem. Next time you hear it, shift into 4x4. If the noise goes away, it's definitely the needle bearing.
    The popping when your suspension articulates is seized lower control arm (LCA) bushings.
  3. Jan 12, 2018 at 9:06 PM
    Notserp
    Notserp Active Member
    Preston
    2015 TRD OR DCSB
    It may be obvious, but don’t shift into 4wheel while going freeway speeds or on turns while on dry pavement.
  4. Jan 12, 2018 at 9:45 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wheel bearing
