humming with truck off..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UncleFrancis, Apr 20, 2013.
  1. Apr 20, 2013 at 5:42 PM
    UncleFrancis
    UncleFrancis [OP] Active Member
    The other day I was messing around in the garage and heard a faint buzzing sound. Started looking around and couldnt find it.
    This afternoon I was in the garage again and I heard the buzzing sound again. Sounds like a small electric motor running. I opened the garage door to see if the neighbors were doing something that was maybe vibrating somethin in my garage. After walking around the garage and not being able to pin point anything. I look at my truck and think to my self.. "I guess ill check" so as I get underneith it its clearly the truck. Above the rear of the gas tank close to the frame crossmember there is a big black box that vibrates (haha no pun intended) now im not real firmiliar with these trucks. the lines and hoses coming off it seem to go to the fuel tank. Is the fuel pump on the outside of the tank on these?? And why is it running? It runs for about 5 minutes and quits and has not done it since. the truck was cold and hadnt been driven or even had a key put in the ignition for about 4 hours. So im going to keep an eye on this as ill be spending some time working on a wood project in the garage for a few days. Anyone else come across something like this. It runs and shuts off on its own so I dont assume theres a short or anything.. Taco is brand new maybe something crazy that ive never heard of??
  2. Apr 20, 2013 at 5:44 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    It's something to do with the gas evap system I believe
  3. Apr 20, 2013 at 5:48 PM
    offroadwonder
    offroadwonder Well-Known Member
    Jared
    Aurora, CO
    '10 Tacoma DCSB 4x4 TRD Off-Road
    Chopped mud-flaps (yup, I'm hardcore)
    Evap emissions purge pump. It pulls the vapors collected by the charcoal canister and pumps it back to the fuel tank. It also runs an evaporative emissions test at the same time.
  4. Apr 20, 2013 at 5:49 PM
    UncleFrancis
    wild. How often does it do this?
  5. Apr 20, 2013 at 6:15 PM
    offroadwonder
    Jared
    Aurora, CO
    Okay, I double checked my facts. The noise you are hearing is actually only an air pump to pressurize the fuel tank to perform the leak-down test that I mentioned earlier (it will throw a CEL code if the pressure is lost too quickly). Purging of the canister will occur while the vehicle is running.
    So anyway, it should perform the test after every few hours of engine run time. But as you noticed it needs to have cooled off before the test will be accurate.
  6. Apr 20, 2013 at 6:18 PM
    UncleFrancis
    Interesting. Well its news to me, at least its normal ha. Thanks for the info.
  7. Apr 20, 2013 at 6:33 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Both my '13 Taco and the wife's '12 RAV4 do it. Sometimes I'll go out to the garage to do something and both of them will be humming along. The manual says it's normal.
  8. Oct 23, 2015 at 10:19 AM
    Dskene76
    Dskene76 New Member
    Douglas
    2016 Toyota Tacoma Double Can 5 ft bef
    Same noise on 2016 Toyota Tacoma. Thank you very much from San Diego, CA.
  9. Oct 17, 2018 at 10:19 PM
    here4cake
    here4cake Well-Known Member
    Found this thread after hearing the same exact noise from my '16 just now. Truck has been off and in the garage for about 6 hours. Didn't do anything when this sound randomly came on. Definitely coming from the same area that has been described in OP - black box above the gas tank.
  10. Oct 17, 2018 at 10:38 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    When did they start using this system, never heard that noise before?
  11. Apr 16, 2020 at 6:32 PM
    cnstaco
    cnstaco Well-Known Member
    CO
    17 DCSB OR
    Mine too and great more electrical nonsense to fail.
