Hunting upgrades! Show me what you got!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Assembly line slave, Jul 27, 2018.
  1. Jul 15, 2019 at 4:29 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
  2. Jul 15, 2019 at 4:49 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    please post a pic of your truck.
    All I see is a tree...
    c0climber likes this.
  3. Jul 16, 2019 at 6:26 AM
    pighitt
    pighitt Member
    Texas
    4x4
    That’s right. I’ve killed tons of pigs and coyotes from there. Sure beat a hot blind this time of year
  4. Jul 17, 2019 at 7:49 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Welded my offset receiver on today and also a tab for my winch power cable. Built a deer winch that swivels 360 degrees a few years ago and used it with my other truck. I offset it so I can open the tailgate and also pull the trailer if I need to haul the golf cart. Took the hitch to my friend to burn/blast/powdercoat today. Here’s a couple pictures of it on my old truck with mr 10 point hanging on. Pay no attention to the round tubing laying there, it’s 3”od 1”id for another job.
    Tacomaman63, CS_AR and Akkording like this.
  5. Jul 17, 2019 at 9:17 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    So... (yes I quoted myself) I figured I'd update the past year's upgrades.
    4wd swap
    Trans shift kit
    Winch bumper
    Warn winch
    Custom built (home made) rear bumper (hi clearance) swing out, tire carrier, gas can carrier
    Sliders
    Roof top tent
    Awning
    Snorkle
    Upsized from 265 to 285
    Headlight upgrade (with satoshi grille and raptor lights)
    Tail light upgrade
    Hella driving lights
    42 inch LED lightbar
    Ditch lights
    Rear LED (with hazard flash)
    Rear LED
    Roof basket
    Pelican case
    Traction boards
    Misc recovery gear (snatch block, tow straps etc)
    HAM (Handheld for now)
    Tablet mount
    New head unit
    Second Optima Yellow top and Aux battery set up
    Replaced Valve Covers, spark plugs, plug wires, throttle body and intake gaskets.
    CS_AR likes this.
  6. Jul 17, 2019 at 9:26 PM
    Wulf
    rock raisin
    @JKO1998 uses his taco to pick up cougars
  7. Jul 17, 2019 at 9:43 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    :cool:
  8. Jul 17, 2019 at 10:37 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    It's a sleeper
  9. Jul 18, 2019 at 1:13 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Was any of the work done in baton rouge? cause i swear ive seen that truck
  10. Jul 23, 2019 at 10:35 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Just picked my hitch up from powdercoat. I’ll get it back on tomorrow. They burned it, sand blasted it, primed it then the black.
  11. Jul 25, 2019 at 11:49 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got the hitch back on. Put a different trailer plug on so I can pull my welding trailer and other trailer as well. Got the winch plug on too. The 6' X 12' trailer I put a hitch on it to put the Warn winch in just incase I need to winch something on it. I made a set of jumper cables to plug in it a while back as well.
  12. Jul 26, 2019 at 8:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here’s the jumper cables I modified to plug into the winch connection. I ran out of small fire hose, used it on the set for my other truck.
