Husky liners vs Weathertech. Help me decide!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bacollier90, Sep 29, 2015.
  1. Oct 8, 2015 at 2:22 PM
    #41
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I have the Weathertechs front and rear and have absolutely no complaints. They are great. But now that I have seen the Huskys in person that is what I will buy next time.
  2. Oct 8, 2015 at 4:49 PM
    #42
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Husky here..
  3. Oct 8, 2015 at 6:32 PM
    #43
    Taco3RZe
    Taco3RZe Member
    Georgia
    03 PreRunner SR5 4cyl.
    I almost went with the Weather-Tech liners again but chose the Husky Weatherbeaters this time in my new 2015 TRD Off-Road Double Cab. So far, I love them, they look and fit great. The genuine all weather (Rubber) Toyota mats were a joke, most notably the driver's side mat. They did not have nearly enough coverage. I think Toyota cut back on the coverage on these mats after the 2010 "Unintended Acceleration" witch-hunt in order to be 'extra careful'. I can't blame them.
    I used the Weather-Tech liners in the past in my old '03 Tacoma and my '08 Lexus ES 350. They proved to be very durable, at least in my old '03 Tacoma, because it was my daily driver and I had no wear issues with them. My main gripe with them is that they did not offer complete protection for the left "dead pedal" or the left foot rest. In my Lexus there is no coverage behind the accelerator pedal with the Weather-tech liners. Water and debris from my left shoe would/do make their way down on the back side of the liner and onto the carpet. The Huskys completely cover the "dead pedal" area and extend farther up behind the pedals.
  4. Oct 8, 2015 at 6:50 PM
    #44
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    That is the only thing that bothers me about the Weathertechs because that is where my muddy left boot sits. Bad design choice.
    And just FYI for those that are considering Weathertechs and were put off by the "doesn't fit manual transmission" Tacos disclaimer, that is only sort of true. The clutch pedal will catch on return with the stock mats but trimming a half an inch with a knife or razor knife completely corrects the problem.
  5. Oct 8, 2015 at 6:55 PM
    #45
    tb3625
    tb3625 Well-Known Member
    Tyler
    Ohio
    2013 Tacoma access sport
    Just got my husky xact contours that I mentioned earlier tonight, I circled the ridge that stops water at the edge by the doorjam. These seem like quality mats, I like the rubber feel to them better then the plastic-like weathertechs
  6. Oct 8, 2015 at 7:18 PM
    #46
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Excellent feature.
  7. Oct 8, 2015 at 7:27 PM
    #47
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Have had Huskey for most all our cars and recently Weather Tech
    They are both excellent products and you can't go wrong with either. We just decided to buy the one now that seems to match the interior best in color And style.
  8. Oct 9, 2015 at 3:32 PM
    #48
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I had the Huskys in my 99 Tacoma but I went with the weather tech in my 2011. Just liked the way they looked. Just my .02 cents.
    Dagosa likes this.
  9. Oct 9, 2015 at 4:00 PM
    #49
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    This is precisely why I got rid of the WT's. All winter long, salty snow melt (nasty white salty water) would drain from that edge down onto the door sill. Husky's solved that!
  10. Oct 9, 2015 at 4:05 PM
    #50
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    Husky's do contain water very well and easily dump when you pull them out from the side...the real problem is, BE CAREFUL PUTTING THEM BACK ON TOP OF THE GAS PEDAL which you can easily do in a rush to dump the salty water from the mats.
  11. Oct 9, 2015 at 9:53 PM
    #51
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    How well does that mat fit against the transmission tunnel, my Husky's have quite a large gap?
  12. Oct 9, 2015 at 10:01 PM
    #52
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    Just got Husky X-act and they fit exactly. Have had a set of the original Huskies that moved from my 94 to my 02 and they have 340 thousand miles on them and are still protecting. Starting to get a little ragged around the edges but not warn through.
  13. Oct 9, 2015 at 10:16 PM
    #53
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
  14. Oct 9, 2015 at 10:20 PM
    #54
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    I have the weather techs. A buddy of mine has the husky's and if I were buying new I would go Husky. It's just a little bit better. Fitment and design.
  15. Oct 10, 2015 at 6:51 AM
    #55
    Larry
    Larry CARL
    CARL
    I've had 2 sets of weathertechs.
    If I get a set to replace the OEM rubber mats. I will go with the Husky.
    A- the rubber is better under four than the hard plastic weathertechs.
    B- the Husky covers the left foot rest.
  16. Oct 10, 2015 at 2:56 PM
    #56
    AwkwardLobster
    AwkwardLobster Well-Known Member
    Las Vegas, NV
    '14 Mag Gray DCSB TRD OR
    I can't compare with the Husky's because I've never seen or owned a set. I do however have the WeatherTechs and have been mostly happy. Between hiking, backpacking, snowshoeing and dirtiest of all, canyoneering, I have really put these mats to the test. Last weekend I had 5 people in my truck in drenched wetsuits and shoes absolutely caked in mud and the WTs did a good job of keeping the floor clean. They do stick out a bit at the edges, but I've seen a really minimal amount of dirt get down there. The edges do overlap the door frame to keep dirt and water out there. I've had standing water in the mats and I was able to carefully lift them out and dump the water without spilling.
    Really my only complaint is they don't cover the driver's side foot rest on the left. Some dirt and mud has dripped down behind the mat on that side, but nothing substantial. Still the potential is there. I included a picture of the floor underneath the mat. A little bit of really fine sand has gotten under near the OEM connections. Given the amount of dirt, mud and water that gets tracked in to my truck every weekend, I'm very happy with the protection the WTs have provided.
  17. Oct 10, 2015 at 3:14 PM
    #57
    Clearwater Bill
    Billy
    Largo Florida
    Poke around in HD and Lowe's in the flooring sections. While they won't be 'mats', you might find a suitable rugged outdoor carpet that would work well.
  18. Oct 11, 2015 at 7:20 PM
    #58
    shakerhood
    Southern Ohio
    I was leaning towards Weathertech's but after reading that Husky's were so good I went ahead and bought them. The passenger side mat fits good but the drivers side really does not, the gap at the transmission tunnel is so large I can fit my entire hand in there, the transition of flat area to the raised areas is right under the clutch pedal so when moving off the dead pedal my heel catches. I have only had them in there for maybe 25 miles and regret buying them, if I had it to do over I would go with the Weathertech's, I may just yank these things out and sell them.
  19. Oct 12, 2015 at 10:23 AM
    #59
    tacofan13
    tacofan13 Well-Known Member
    JR
    2017 Quicksand DCSB 4X4
    I have had WT and Husky xact fit. I prefer the Husky mats for fit and finish.
  20. Oct 12, 2015 at 5:31 PM
    #60
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Can the HUSKY decal be easily removed from the xact contours?
