HVAC control lights are out
Discussion in 'Lighting' started by jacoblb, Oct 5, 2020.
  1. Oct 5, 2020 at 2:45 PM
    jacoblb
    jacoblb [OP] Well-Known Member
    MD
    2010 AC 2.7L
    The lights on the knobs of my HVAC controls have been out. The A/C button light works. I replaced the bulbs to LED, nothing, put new incandescent bulbs in, nothing. Found a burned tail light fuse, replaced it and still nothing. Tail light is good now. What else should I look at? 2010 Access I4 4x4.
  2. Oct 10, 2020 at 7:19 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Similar problem, half my HVAC lights work. Sometimes none of them work, then if I tap the panel hard a dozen times half will light up, whats weird about it is sometimes its one half and sometimes its the other half... I have taken it apart to no avail. No broken bulbs
  3. Oct 10, 2020 at 7:48 PM
    jacoblb
    MD
    2010 AC 2.7L
    If it helps, I swapped my buddy’s good panel in and the lights worked. So the issue with mine is in the panel. I’m just going to purchase a new one fwiw.
  4. Oct 13, 2020 at 1:24 PM
    007fodo
    007fodo Gold Member
    Ian
    4X4 V6 5AT DCSB 07
    That just makes me want to tear mine apart again haha. Nah... thanks, that does help
