HVAC controls randomly go crazy on startup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by plurpimpin, Sep 25, 2015.
  1. Sep 25, 2015 at 10:14 AM
    plurpimpin
    plurpimpin [OP] Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I've been having a really weird problem with my HVAC controls for the last few weeks. Sometimes when I start the truck it will turn on with the AC and Recirc on regardless of the settings when I turned it off. Then the AC will stay on even if I press the button. When the AC does turn off it'll often come right back on. The recirc button acts similarly. The truck only does this when I first start it and it goes away and the controls return to normal after running for a few minutes. It does not do this every time I start it, probably once or twice a week.
    Could something be shorting out? I'd be willing to replace the panel if it'll fix it. I just hate throwing parts at a problem not knowing if it's the correct fix.
    I have done the No AC with defrost and disable max AC mods but those were done months before this problem started up. Anybody ever experience anything similar or have any ideas? Below are two videos of it acting up this week.
  2. Sep 25, 2015 at 12:43 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Have you pulled the cluster and checked the wire harness?
  3. Sep 25, 2015 at 2:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    First I would start here at the mods. Something may have come loose.
  4. Sep 25, 2015 at 2:24 PM
    plurpimpin
    PDX
    I'll check them but I did defrost without AC when I bought the truck 4 years ago and the other one back in March. Plus I would think if it was mod related it would happen randomly when the wires short/are out of position. The issue only ever arises when I start the truck and then its fine regardless of if I drive 10 minutes or 6 hours.
    I'll double check all the connections this evening to be sure nothing came loose
