HVAC controls
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HawkShot99, Apr 30, 2022.
  1. Apr 30, 2022 at 9:16 AM
    HawkShot99
    HawkShot99 [OP] Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I have a 13', and recently the fan (both heat and ac) works on 1,2,and 3 as it should. When I turn the control to 4, it drops down and blows weak at maybe a 1-2 strength.
    I know it's not the resistor, as I recently replaced it as it had some burn marks on it and that did not change anything.
    It's not the actual blower. My dad has a 11' Tacoma. I swapped his blower and mine. My blower worked on all 4 settings in his truck, his blower now has the same issue in my truck.
    What else could be why I lost setting 4?
    Thanks.
  2. Apr 30, 2022 at 9:28 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    The control knob switch.
  3. Apr 30, 2022 at 9:32 AM
    Bishop84
    Bishop84 Well-Known Member
    Did you replace the connector to the resistor as well? They burn on the inside of the female pins.
  4. Apr 30, 2022 at 9:37 AM
    HawkShot99
    Kingston, NY
    Yes. Cut the wires and added a new plug + resistor. I had done that several years ago so was familiar with that job.
    I'll try swapping the control panel and see if that fixes the issue. I don't want to just buy parts blindly, so it's nice borrowing my dad's truck parts.
    Bishop84[QUOTED] likes this.
  5. Apr 30, 2022 at 9:38 AM
    Bishop84
    We call it "Swaptronics" Haha Good luck.
    INSAYN likes this.
  6. Apr 30, 2022 at 10:00 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Is it possible you didn't wire the resistor wires correctly? Maybe check that against your dad's truck too while you're down there.
  7. Apr 30, 2022 at 10:16 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Double check the resistor wiring.
    And also check the control panel wiring and connector. It’s been know to melt too.
  8. Apr 30, 2022 at 11:13 AM
    HawkShot99
    Kingston, NY
    I am almost certain the plug is correct for the resistor. Regardless, the fan was doing this before I replaced the resistor and plug. I'll see if the 11' tacoma fan switch assembly will work, as from pics it looks different then my 13'.
  9. May 1, 2022 at 2:16 PM
    HawkShot99
    Kingston, NY
    So I swapped in my dad's control panel. It operated the fan properly. The fan plug is the same, but the ac plugs are different so they can't be swapped.
    There was a light burnt mark on one of the plugs. So I went to reinstall the panel as it still mostly works and I d look into a new panel.
    Once all reinstalled, that fan now works on all settings. So I'll run it as is for now, and keep a new panel in mind. Used ones look to be around $150.
    Thanks for the answers guys.
    TnShooter likes this.
