HVAC duct control?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mblank80, Oct 18, 2015.
  1. Oct 18, 2015 at 11:40 AM
    mblank80
    mblank80 [OP] New Member
    north of Pittsburgh, PA.
    Tacoma TRD sport 4x4
    Hello,
    I have a 2013 trd sport 4x4.
    My drivers side heater dash vent always has air flow even when selector is set on floor or windshield/defrost. Very annoying haveing heat blowing in your face all the time.
    The selector switch works (blows on the floor when selected and windshield when defrost is selected) but always coming out of drivers side dash vent.
    Has anyone else had this problem?
    Any ideas on how to fix? I'm not sure how the duct work is controled, cable or elec. motor?
    Thanks
  2. Oct 18, 2015 at 11:45 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    the very outside dash vents are blowing to defrost side windows, just like about every car on the road. The vents are suppose to blow around you to circulate the air inside for optimum hvac efficiency, not directly at you.
    because_wumbo-truck likes this.
  3. Oct 18, 2015 at 12:38 PM
    mblank80
    thanks for the reply, but either I didn't explain my problem correctly or you misunderstood what I was saying.
    The vent beside the gauges to the left of the steering wheel is always blowing air. Niether the one on the right side or the middle vent are blowing. For now I just shut the louvers but a lot of heat still gets out.
    Also, my buddies 2012 Tacoma does not always have flow always coming out of that vent as u said.
    It most likely is a flapper in the ductwork that controls the flow to that vent but I'm not sure, just want to see what you guys have to say.
    Thanks
  4. Oct 18, 2015 at 12:45 PM
    MonroeTaco
    MonroeTaco Well-Known Member
    Winder, GA.
    2021 Off Road
    Push and hold the recirc button for 5 seconds.
  5. Oct 18, 2015 at 1:18 PM
    mblank80
    I pressed and held the circulation button (button with the pic of a car with the half circle arrow) I hope that was it. It did not work.
    Thanks for trying.
  6. Oct 18, 2015 at 1:31 PM
    gottaToy
    JJ
    1985 Moped
    on defrost/windshield, IT DOES BLOW OUT THE VERY OUTSIDE DASH SIDE VENTS, how else would it defrost/defog the sides? It also blows there when on the floor, just not as much.
    TURN THE VENT SO IT DOESN"T BLOW ON YOU, problem solved
  7. Oct 18, 2015 at 1:33 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    when switched to the window defrost only, there is no way to turn it off. switch it to the one that has the arrow pointing to the floor and the defrost picture, then hold the recirc button for 5 seconds. reminder, this will be reset every time you turn it on.
  8. Oct 18, 2015 at 1:37 PM
    gottaToy
    JJ
    1985 Moped
  9. Oct 18, 2015 at 1:39 PM
    gottaToy
    JJ
    1985 Moped
    I understood what you were saying, read the owners manual. If the right side isn't blowing air, it is broke. The outside dash vents blow for every setting other then OFF
  10. Oct 18, 2015 at 2:02 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Both outside face vents are supposed to blow air ALL THE TIME regardless of the HVAC settings. Toyota provides a separate means for shutting off those vents manually if you don't want the air coming out them. Been this way for at least the last 30 years.
    because_wumbo-truck and gottaToy like this.
  11. Oct 18, 2015 at 2:32 PM
    gottaToy
    JJ
    1985 Moped
    Gotta love the people that ask questions, but don't like the answers. Then swear you are wrong and they suddenly know the answer to their concern.
  12. Oct 18, 2015 at 3:58 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    If the the truck isn't blowing, you could correct it by profusely inhaling the nearest pole.
  13. Oct 18, 2015 at 3:59 PM
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
  14. Oct 18, 2015 at 4:03 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
  15. Oct 18, 2015 at 4:05 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  16. Oct 18, 2015 at 4:06 PM
    23Skidoo
    Paul
    meme
  17. Oct 18, 2015 at 4:06 PM
    Old School
    Old School You are ignoring covfefe by this member.
  18. Oct 18, 2015 at 4:10 PM
    23Skidoo
    Paul
    meme
    This is an epic failure on Toyotas part.
    MQQSE likes this.
  19. Oct 18, 2015 at 4:13 PM
    Old School
    How can this not be a third gen problem?:laugh:
    MQQSE and 23Skidoo like this.
  20. Oct 18, 2015 at 4:33 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Is there a separate means OTHER than shutting the louvre with your finger?
    Personally to me it is annoying when I select floor for heat yet have heat coming out the side vents by the window to then have to manually shut the louvre in the morning but then mid day having to remember to open the sides so not all the cool air is coming out the two middle vents - on either side of the radio.
