HVAC during remote start..?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toyotahenry, Dec 26, 2023.
  1. Dec 26, 2023 at 8:06 PM
    toyotahenry
    toyotahenry [OP] N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    This morning i remoted started my truck and left it running for 10 minutes. When i got in my truck, it was still cold as heck. Was 10 minutes not enough run time to heat up the interior or is something wrong? TIA!
  2. Dec 26, 2023 at 8:18 PM
    Bishop84
    Bishop84 Well-Known Member
    As long as you leave it on auto thats all you can do.
    If you leave the fan on full blast it actually slows down warm up.
    Texas can't be that cold can it? Freezing? We are around freezing and I wear a hoodie and remote start for 1 minute lol.
    toyotahenry[OP] and Chew like this.
  3. Dec 26, 2023 at 8:21 PM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    As Bishop84 said, maybe lower fan speed, direct to the floor and let the truck be "tolerable" instead of "toasty" when you get in.
    But I live in PHX ... morning lows here mid-40s. Is Houston really that much colder?
  4. Dec 26, 2023 at 9:03 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I don’t have climate control, so I leave mine on the second speed (slower side, and I think there’s 4). As mentioned, having the fan way up will cause a longer warm up.
    If you do have climate control, leave it on Auto, and it will adjust fan speed as temps rise.
    Idling takes much longer to bring up temps than driving.
  5. Dec 26, 2023 at 9:16 PM
    Trail Limo
    Trail Limo Well-Known Member
    Best bet is to set to defrost. There is a resistive heater that is used to speed up defrosting the windshield. Won't really help heat the cab though.
    Big tall dave likes this.
  6. Dec 26, 2023 at 9:47 PM
    toyotahenry
    Houston, Texas
    son of a gun.. so that means i need to toggle “auto” each time prior to remote starting to have the most optimal interior temp.
  7. Dec 26, 2023 at 9:55 PM
    Bishop84
    Honestly auto is best anyways, set it to 72 or whatever and leave it. If its cold it will max itself out to warm up as fast as it can.
    The idea is to keep the fan speed low while it warms up. Which it will on its own. Including using defrost as a warm up.
    musicisevil and Chew like this.
  8. Dec 26, 2023 at 11:02 PM
    rds54
    rds54 Well-Known Member
    I have found that using the floor heater & defrost works better than straight defrost/cabin ventrs, I set to max heat and fan speed works for me. Due to what other people in here are saying im gonna try that at half speed next time
    Just wish the mirror defroster would turn on with remote start
    Chew likes this.
  9. Jan 15, 2024 at 11:54 PM
    toyotahenry
    Houston, Texas
    well i'm sorta pissed off. during remote start the recirc and a/c buttons are not activated. i'll have it at medium fan speed on HI temp and will still come out to a COLD truck nearly 10 minutes after remote starting. this is starting to become frustrating.
  10. Jan 16, 2024 at 12:43 AM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    I can warm mine up for 15 minutes and it's barely warming up the interior....currently -6 where I am at though.
  11. Jan 16, 2024 at 12:46 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    The HVAC system is intricate to say the least and does not turn on the HVAC system on a standard vehicle. I installed an aftermarket compustar alarm and remote start but eventually figured out how the have HVAC accessories powered. The install included programming the alarm outputs through the idatalink software to include enough custom outputs to power 2 starter and 2 ignition cables in order to have HVAC turn on with the remote start.
    I've had perfecly running AC and/or heat on every remote start since. It's not an easy feat and requires that your aftermarket alarm system has programmable outputs.. not sure if this could be achieved with the OEM system.
    Edit:
    Please refer to thread I posted a couple years ago.. https://www.tacomaworld.com/threads/ac-wiring-for-remote-start.617206/
  12. Jan 16, 2024 at 3:16 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Depends on the ambient temp.
    Yesterday I used remote to start, the temp in the show was 11*. I ran mine for 10 mins, it wasn’t WARM, but the needle was just off the cold mark. HVAC was set to vent and floor, temp to 70*
    Works pretty darn good for me. Everyone is different. Since it was -3* outside the shop, I was pleased.
  13. Jan 16, 2024 at 8:55 AM
    toyotahenry
    Houston, Texas
    was your A/C and recirc button on when you had got into the vehicle?
  14. Jan 16, 2024 at 9:06 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Before I shut my Sport off, I adjust the fan speed to 2 bars, press the recirculate button and adjust temp to 68F while indicator is set to defrost.
    I remote start my truck and it does its thing for 10 mins.
    When it's time to drive my truck, the fan speed/recirculate and temp are all on the way I left them.
    The truck's interior temp is as expected but then I adjust fan to high and bump the temp to 72F and I'm good.
  15. Jan 16, 2024 at 5:33 PM
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    i don't. before i get out of the truck i set it to defrost and turn the fan speed to 2 bars. with auto start i'm just looking to get a head start on getting the ice off the windshield so i can get in and drive away. the fact that the truck is warmer inside than it is outside when i get in is a bonus. this morning it was 18* when i got in the truck and that worked fine. but it's winter, i'd suffocate if the truck was 70* inside. i have to turn down the defrost just as soon as the windows are clear.
    TacoTime55 likes this.
  16. Jan 16, 2024 at 5:57 PM
    Williston
    Williston Somewhat-Known Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    On some GM cars with climate control, if the system is set to "Auto" it will activate/run the Climate Control to bring the vehicle up to the set temperature on a remote start. If it's winter, it will delay the fan until the engine temp is sufficient and then run it at High until the temp comes up to the set speed. Conversely: if you leave it on "defrost" or any other outlet setting, it will use that. Useful if you know it's going to snow all day.) In the summer, the system will activate the A/C in recirc mode until the set temp is reached and it will then switch over to fresh. Some also have solar and humidity sensors to activate the A/C when detected interior humidity was high or the sun angle was at high noon. Some of them would open all of the windows (and sunroof, if equipped) if you clicked the remote thrice.
