HVAC Help
Discussion in 'Garage / Workshop' started by Maticuno, Jun 25, 2016.
  1. Jun 25, 2016 at 6:06 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    The a/c condenser fan quit working on my home's HVAC system. After a reset, the compressor will turn on just fine. The fan blades and motor shaft spin freely, but the housing is super hot to the touch. It seems like a pretty straightforward replacement job, including the dual action capacitor, but I'm wondering what would make the motor give out without a seized bearing or something similar? Carrier Tech 2000 SS model for reference.
  2. Jun 25, 2016 at 6:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    No AC tech here, but most of what I've seen (besides big component failure) is control wiring/circuit board failures.
  3. Jun 25, 2016 at 6:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Have you tried spraying the coils down with water?
    High head pressure will prevent the fan motor from starting.
  4. Jun 25, 2016 at 6:32 PM
    Maticuno
    2011 Suburban 2500
    Wouldn't high pressure prevent compressor startup, not fan?
  5. Jun 27, 2016 at 7:09 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    No circuit boards on that model.
    OP, test the relay of the fan. The fan's job is to help reject the heat in the condenser coils.... no fan operation will not cool the hot coils...... hence the unit is hot.
  6. Jun 27, 2016 at 7:16 PM
    File IFR
    Central MA
    Correct
  7. Jun 27, 2016 at 8:14 PM
    Maticuno
    2011 Suburban 2500
    On closer inspection, I found the capacitor seal was leaking, so I'm assuming dead capacitor. I have a new one on the way.
    As for the relay, there is only one. It controls both the compressor and condenser fan. Since the compressor was still starting, I'm hoping the condenser fan was just in thermal overload.
  8. Jul 1, 2016 at 8:50 PM
    Maticuno
    2011 Suburban 2500
    Replaced capacitor and all is well. So far, so good.
