Hwy wandering
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, May 19, 2010.
  1. May 19, 2010 at 12:49 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    My Taco feels like its wandering on the Hwy :eek:
  2. May 19, 2010 at 12:50 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    get an alignment? also with the lift you have you may need aftermarket UCA's if you want a near perfect alignment
  3. May 19, 2010 at 12:51 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Alignment?
  4. May 19, 2010 at 12:57 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I'll go to Fountain Tire down the road and get it checked out...
  5. May 19, 2010 at 12:59 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Since you have a lift. Your caster is probably too low.
  6. May 19, 2010 at 1:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wander (bump steer) can be caused by worn suspension components but if you've just added lift in front with spacers or coilover shocks or lift springs, the most likely cause is low caster.
    An alignment shop can adjust the caster to a point on our trucks that should eliminate some if not all 'highway wandering' seen after a lift.
  7. May 19, 2010 at 2:07 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Great!!! Thx for the help guys :D I'll let u know what the shop says is the issue for the wandering...
  8. May 19, 2010 at 6:23 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Have the shop adjust the camber or compromise on camber to get caster close to 1.5 or better. You can keep camber in tolerance but adjusted so you can get more caster. Caster is causing the wandering
    If they know what they are doing and you tell them what you want you can get it to where it will be better on the caster but it will make the shop go back and forth on camber and caster to get the caster closer to spec > 2.0
    It took about 2 hours of work to get my caster at about 1.4 and that was good enough to stop the wander I was feeling but I am still out of spec <2.0
    But.. I didn't spend 600 on UCAs
  9. May 20, 2010 at 3:28 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Tie Rod Ends are all seized up :( $750 parts/labour + taxes
    They tried heating them up with no luck and put some nut buster lube on to see if it helps out...Shop said I have excessive Toe in which is probably contributing to my horrible gas mileage 300km per tank and extreme outside tire wear on my expensive M/T :eek:
  10. May 20, 2010 at 3:31 PM
    270 Well-Known Member
    Jeff
    California
    09 Dc 4x4
    Man what a bummer sorry to hear that.
  11. May 20, 2010 at 3:34 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I know...Oh well it's only $$$ haha and I love my Taco :D so it's going into the shop on Wed to get all fixed up...
  12. May 20, 2010 at 5:15 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I'm really curious to see how much my gas mileage improves :rolleyes:
  13. May 20, 2010 at 5:30 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    yah that is pretty shitty gas mileage even with 33's, keep us posted man
  14. May 21, 2010 at 12:00 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Are TRE's expensive parts to replace??? seems like a lot of $$$
  15. May 21, 2010 at 12:10 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    RockAuto.com has the outer tie rod ends for your truck for less than $15 per side. Inners are around $50 each.
  16. May 21, 2010 at 12:46 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    I heard the made in Taiwan ones are crap and I would end up replacing them again in a year or so...The ones I got quoted on are Moog...
  17. May 21, 2010 at 12:53 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    If you can afford the Moog's, I'd go with them. They make a quality product and stand behind it.
  18. May 21, 2010 at 12:54 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    :eek:
    • Taco.pdf
      File size:
      58.5 KB
      126
  19. May 21, 2010 at 1:05 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    should I be replacing anything else along with the TRE's :confused:
  20. May 21, 2010 at 5:26 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    CT quoted $110 higher than FT...I found a little hidden shop who won an award for being the most honest shop for 2010...There gonna take a look at my taco next week to see if they can unseize the TRE's...Is there any recommend lubes I should be putting on them in the meantime so it soaks for a couple days to help out a bit?
