Hy I’m new to the forums but I am mechanically inclined and usually fix problems with my 1995 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Will4x4taco, Feb 12, 2024.
  1. Feb 12, 2024 at 5:28 AM
    Will4x4taco
    Will4x4taco [OP] New Member
    William
    Tacoma gen1 4x4 trd
    My problem is my 1995 Tacoma 4x4 3.4 is not engaging the front axle. The front drive shaft is turning when shifting into 4 wheel drive. My model does not have the button for 4 wheel drive the later models have. The front axle does not engage and the light does not come on. I don’t know where to start. I have checked the 10 amp fuse and it is good. Maybe I should start checking vacuum pump and lines. I know where the ADD is on the front axle, it looks like 2 vacuum lines and one electrical connection. Very hard to access or even see it. Any help would be appreciated. Thanks
  2. Feb 12, 2024 at 7:46 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    How long has it been since it would engage ?
    The actuators do tend to hang up if not engaged every few weeks.
    My check is a hand held vacuum pump making sure the actuator moves free
    vacuum lines can dry rot . Vacuum Switching valves can die of old age.
    your looking up from the bottom with the splash shield removed?
