Hybrids only thread.
Discussion in '4th Gen. Tacomas (2024+)' started by gmtech, Sep 30, 2024.
  1. Apr 15, 2025 at 11:13 PM
    #281
    TacomaBuyerBC
    TacomaBuyerBC Member
    Anyone also notice a subtle vibration through the steering wheel almost as if the engine is lugging due to the transmission being in too high of a gear? It tends to happen driving at speeds of 80km/hr to 90km/hr.
  2. Apr 15, 2025 at 11:20 PM
    #282
    JimScotty
    JimScotty Well-Known Member
    2024 Tacoma TRD Pro
    You might find that more common using ECO mode where it will favor higher gears. You will have a different experience when using Normal or Sport modes.
  3. Apr 15, 2025 at 11:32 PM
    #283
    TacomaBuyerBC
    I’ve noticed it in both Normal and Eco mode which is the surprising part.
  4. Apr 16, 2025 at 6:14 AM
    #284
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Slight shudder under light throttle, similar to being in a gear too high. Noticed it early, disappeared after break-in. Either I subconsciously altered my driving to it, or more likely, the computers adapted to me.
  5. Apr 16, 2025 at 6:36 AM
    #285
    gmtech
    gmtech [OP] Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    how many miles on lunar squirrel's? im at 9500 on mine in 6months.
  6. Apr 16, 2025 at 8:12 AM
    #286
    Lunar Squirrel
    I’m only at 2300mi.
  7. Apr 17, 2025 at 6:08 AM
    #287
    Lunar Squirrel
    If someone is considering purchasing a hybrid, just know that there’s a lot going on here, with associated noises and some vibration that can easily be interpreted an issue. The hybrid is awesome, but I can only imagine what someone trading a 2012 4.0 on this might be thinking.
    Looking back at the amount of new owner complaints that just D4S created in 2016 (ticking, clean cycle..) should’ve informed Toyota that introducing hybrid powertrains to your most conservative group of owners would require some education at the dealer level. That hasn’t happened b/c too often we just hear, “normal”. Well, probably it is, but maybe not, so for an extra 3 grand, we shouldn’t have to debate it on owner forums. It’s still early, so not too late to see Toyota get in front of it instead of reacting all the time.
  8. Apr 17, 2025 at 6:47 AM
    #288
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    I don't mind the whirling noise at low speeds when the electric motor kicks in. I think its cool and given that i've driven tesla a handful of times, I am use to it. My unease issue is when the motor transitions from Electric to Gas there is quick vibration.
    Kind of like the traditional off/on of the engines in todays car. It isn't smooth and seamless like some people are reporting or maybe my truck with 600 miles on it has an issue. Similar to many others who are experiencing the same.
  9. Apr 17, 2025 at 10:04 AM
    #289
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Ah yes, the second gen Tacoma, the world's smoothest vehicle with the world's quietest engine.
    I hear what you're saying, and I loved my 2012 Tacoma, but it was far from a refined vehicle.
    wfxt and Lunar Squirrel[QUOTED] like this.
  10. Apr 17, 2025 at 12:57 PM
    #290
    JimScotty
    2024 Tacoma TRD Pro
    This is my first Tacoma Hybrid (Pro), but I have had 3 other Toyota Hybrids for about 13 years. I love the Hybrid concept and find the Tacoma Hybrid works just fine. Toyota knows Hybrid better than anyone and having it in a truck gave them a challenge that I believe works very well.
    gmtech[OP] likes this.
  11. Apr 17, 2025 at 4:35 PM
    #291
    TPRO25
    TPRO25 New Member
    Rick
    2025 Tacoma PRO
    Diamondback HD Cover
  12. Apr 17, 2025 at 4:36 PM
    #292
    TPRO25
    TPRO25 New Member
    Rick
    2025 Tacoma PRO
    I have a 25 TRD Pro. First 2 tanks were 13.5 mpg and now up to 16.1 driving like grandpa. Not crazy about the 2.4 but love the truck.
    Fast1 likes this.
  13. Apr 21, 2025 at 10:33 AM
    #293
    gmtech
    Stock AF
    how many of you guys use the brake hold feature? the switch behind the parking brake switch. i have found that it kinda works like a tiny launch control! if you have brake hold switch on and shifter in s8 so engine does not shut off , then kinda stab it when you want to go its kinda like a tiny brake torque before it launches.
  14. Apr 21, 2025 at 11:33 AM
    #294
    Taco Ji
    New Jersey
    Never really used it on any of my vehicles.
  15. Apr 21, 2025 at 11:39 AM
    #295
    IIIAWOLIII
    IIIAWOLIII Well-Known Member
    Jim
    Florida Space Coast
    2024 TRD Offroad Hybrid
    Changing gears a little: Aside from the electric motor and hybrid battery, what other significant differences exist on hybrids only?
    - Larger regenerative front brakes
    - 18" wheels instead of 17" wheels
    - Larger drive shaft
    - No auto start/stop button (instead only a "Ready" dash indication)
    - Fixed rear seat bases
    Other differences?
    Fast1 and Taco Ji like this.
  16. Apr 21, 2025 at 11:44 AM
    #296
    Taco Ji
    New Jersey
    I think the rear bed outlet is 2400 watts vs 1200 watts? And of course more power!!!!
    Fast1 and IIIAWOLIII like this.
  17. Apr 21, 2025 at 12:19 PM
    #297
    gmtech
    Stock AF
    vs 400w. no alternator. rear seat bottoms do raise. just have to remove 2-3 plastic push pins. 12v battery is under drivers seat. a/c -heat work with engine off because vehicle has electric a/c compressor.
  18. Apr 21, 2025 at 12:32 PM
    #298
    wktjr1
    wktjr1 Active Member
    The 2025's now have alternators.
  19. Apr 21, 2025 at 12:49 PM
    #299
    gmtech
    Stock AF
    link? pictures?
  20. Apr 21, 2025 at 12:52 PM
    #300
    wktjr1
    gmtech[QUOTED][OP] likes this.
