Hybrids only thread.
Discussion in '4th Gen. Tacomas (2024+)' started by gmtech, Sep 30, 2024.
  1. May 3, 2025 at 6:27 AM
    #361
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Just an fyi. You can’t just click a button and be in electric mode. It depends on your speed and acceleration pedal pressed.
  2. May 3, 2025 at 6:30 AM
    #362
    gmtech
    gmtech [OP] Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    i think ive got 1.5 -2 miles. coast down hill through neighborhood california stopped some stop signs and tight turns .
  3. May 3, 2025 at 8:35 AM
    #363
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    The injection seat!
    It looks pretty good.
    18trdsport, codeblue! and gpb like this.
  4. May 3, 2025 at 9:44 AM
    #364
    dleithaus
    Washington State
    Poverty edition upgrade.
  5. May 3, 2025 at 11:07 AM
    #365
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Love it!
  6. May 4, 2025 at 10:35 AM
    #366
    MagnoliaPhil
    MagnoliaPhil Active Member
    Tri-Cities, WA
    2024 Tacoma Limited I-FORCE MAX, Celestial Silver
    No changes other than window tint & door vent visors
    Updating my earlier comment regarding speedometer accuracy. I've spent some time since the last post comparing the speedometer reading on my Tacoma with both Google Maps and a Speedometer app that I downloaded - both using GPS - and my own truck is in fact consistently showing 1+ mph over what the GPS shows. The radar monitors at my work site that I referred to earlier are showing the same thing so I think they are accurate and my Tacoma is optimistic.
    It's not a huge thing although I'd prefer the speedometer to be closer to exactly accurate.
  7. May 4, 2025 at 3:22 PM
    #367
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    This has been the case for me for every I've driven while using a gps. Usually it's more like 2-3 mph off at 50-60, so I'd say 1 mph difference is pretty good.
  8. May 10, 2025 at 8:36 AM
    #368
    Sullivan0930
    Sullivan0930 Well-Known Member
    Daniel
    2024 TRD Offroad. iforce max. Bronze oxide.
    I can’t find a clear answer on this but do hybrids have different suspension setup than regular TRD? I know the wheel and tire make it sit higher but would adding the TRD lift kit make any difference?
  9. May 10, 2025 at 2:23 PM
    #369
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    Back in the day when I was restoring a 1969 Camaro, there were coil springs for small block cars, sm block with AC, big block, etc. Different weights/options dictated different springs.
    Not sure if Toyota uses different springs for the hybrids (other than Pro/TH). If they do, seems like they would need two different lift kit options.
  10. May 10, 2025 at 2:46 PM
    #370
    1Strailhunter
    1Strailhunter Active Member
    Florida
    2025 Tacoma Trailhunter Bronze oxide
    Yes, I was wondering about that too cause all the 24 th vid on youtube has only 3
  11. May 18, 2025 at 9:12 PM
    #371
    LN13
    LN13 Well-Known Member
    Arizona
    2024 TRD OR Hybrid
    4K package 2024 TRD OR Hybrid...no alternator and 3 aux switches. I also just had my truck sit for almost 8 days in garage, I got home and drum roll please...............it started up with zero issues.
    gmtech[QUOTED][OP] likes this.
  12. May 19, 2025 at 5:27 AM
    #372
    H2o-Bar
    H2o-Bar Active Member
    My 2025 Trailhunter has 4 aux switches and an alternator. Wouldn't have know to look without this thread.
  13. May 19, 2025 at 8:14 AM
    #373
    caribe makaira
    Caribbean, Puerto Rico
    Would someone be so kind and post a pic of the headlights assemblies connectors. I'm trying to find out if a differ from the non-hybrids connectors.
  14. May 19, 2025 at 9:58 AM
    #374
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    Are you referring to the wiring connectors or housing? Here are some of the electrical connectors:
    Edit: Below post indicates a third electrical connector. Must of missed it. Will check back and edit this post.
  15. May 19, 2025 at 10:36 AM
    #375
    JimScotty
    JimScotty Well-Known Member
    2024 Tacoma TRD Pro
    I am interested also. I believe both are at least different on the TRD Pro Hybrid as it has sequential directional signals. From my incomplete examinations, I believe my PRO has 3 connector harnesses going to the housing. I am not sure yet which one does what.
  16. May 19, 2025 at 3:18 PM
    #376
    snickers
    I assume you are in Canada. How many packages of wiring connectors did you get with your truck? Does your manual indicate the connector locations?
    TheWildMan likes this.
  17. May 19, 2025 at 3:28 PM
    #377
    caribe makaira
    Pics?
  18. May 22, 2025 at 6:22 PM
    #378
    JimScotty
    2024 Tacoma TRD Pro
    It is hard to get a good pic, but I see what I believe to be 3. I am not sure which one does what. I can't get my hand in there to figure out how to remove a connector so I am waiting on my son to assist me.
    20250425_180240.jpg 20250425_175113.jpg 20250422_150435.jpg 20250422_145938.jpg
  19. May 23, 2025 at 4:55 AM
    #379
    snickers
    If the black plug is what you are referring to, it is the circuit for the aux switches. You are looking at the plug for weather sealing. You should have a set of associated cables/connectors that came with your truck.
  20. May 23, 2025 at 10:47 AM
    #380
    caribe makaira
    These 3?
    Top Black is Turn/Parking and ground, middle black unknown. White is Low/High/Turn and ground.
