Hybrids only thread.
Discussion in '4th Gen. Tacomas (2024+)' started by gmtech, Sep 30, 2024.
  1. Oct 22, 2024 at 11:24 AM
    #121
    BaltimoreMD
    BaltimoreMD Well-Known Member
    4gen Taco Ltd HV
    I would check first that the necessary vehicle adaptations would be possible, as that might immediately rule it out. If it does not, Toyota's warranty on Hybrid systems is 8 years. It's a separate warranty than the normal 3yr/5yr non-hybrid components.
  2. Oct 22, 2024 at 11:59 AM
    #122
    Lennyz1
    Lennyz1 Well-Known Member
    Len
    2024 TRD Sport Premium Hybrid 4x4 Bronze Oxide
    Yes, they are very reliable long term from my experiences. There are always people talking about the price to replace a failed hybrid battery in 5 years and this just not happen. The reason Toyota will warranty a hybrid system so long is that it should not fail in the time frame (Fed law says they have to for 8 years / 100,000 miles). I had a gen 2 Prius for 11 years and it had just over 160,000 miles on it. Brakes, tires, one front wheel bearing, oil changes and gas is all that I ever did to that car. Nothing else went wrong until my daughter put it into a power pole. I had no noticeable battery degradation in the hybrid battery. Toyota put limitations on the battery usage through software which limits discharge and over charge on the hybrid battery which is what extends the life drastically.
    I certainly would not be concerned about buying a hybrid for longevity, but it certainly depends on it working for your specific situation.
    rick1201 likes this.
  3. Oct 22, 2024 at 10:07 PM
    #123
    Bogeypro
    Bogeypro Member
    2024 Ice Cap TRD OR hybrid
    same here. Mine is smooth as silk.
  4. Oct 23, 2024 at 8:32 AM
    #124
    sogtr
    sogtr Well-Known Member
    2024 Tacoma Trailhunter Ice Cap
    i visited my dealership to get some info on TSB, and they said for i got 60k miles if something happens.
  5. Oct 23, 2024 at 8:33 AM
    #125
    JB_TN
    JB_TN Well-Known Member
    JB
    Tennessee
    2024 Bronze Oxide TRD OR
    Seems about the right response.
  6. Oct 25, 2024 at 7:29 PM
    #126
    Scott Zinger
    Scott Zinger New Member
    Scott
    I noticed today that the badge on my tailgate is crooked, WTH!! IMG_4769.jpg
  7. Oct 27, 2024 at 10:23 AM
    #127
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    soetaco, vprgts and Canadian Caber like this.
  8. Oct 28, 2024 at 4:13 AM
    #128
    sogtr
  9. Oct 28, 2024 at 6:45 AM
    #129
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    LOL. You should see the vinyl B pillar wraps on mine (3rd Gen). Not good. These are the types of things that dont happen with Toyotas built in Japan.
    Vidman likes this.
  10. Oct 28, 2024 at 3:42 PM
    #130
    gmtech
    gmtech [OP] Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    One long mountain downhill and got a full charge!
  11. Oct 30, 2024 at 8:55 AM
    #131
    BBurgDave
    BBurgDave Well-Known Member
    Dave
    Blacksburg, VA
    2017 Tacoma SR5 Access Cab
    I'm not an owner of a hybrid and I am reading this thread because I just heard about the Tacoma hybrid and I am "hybrid curious". I've got a 2017 Tacoma with about 35K miles on it and I would consider upgrading if I could convince myself it was worth the money. My truck is a 4x4, 6' bed on extended cab and I can have a towing capacity of 6400 lbs. I use Fuelly to track mileage and my truck has averaged 18.3 mpg over it's life. When I saw the specs of the Tacoma truck I will admit that I was very disappointed to see the claimed combined MPG of 24, I was hoping for better. Since I am an MPG over torque person (that said, I don't want to give up torque or towing capacity), I guess this first iteration of the hybrid truck may not be it for me yet, so maybe I will have to wait for a plug-in version of the truck, or a plug-in Ranger in the US (both of which are uncertain at this point. Sigh! :)
    LN13 likes this.
  12. Nov 3, 2024 at 3:05 AM
    #132
    BaltimoreMD
    4gen Taco Ltd HV
    Random aside: Hybrid vehicle battery access.
    Did this the other day just to look around and understand for the day 3ish years from now that the 12v will need changing.
    Access is by three two-step push pins along the front edge right below the cushion. Spaced about center of each passenger seat position. Easiest removal is with a plastic trim tool with a forked front. Once all three are fully removed, the two parts (it is still a 60/40 split) will flip up. I had no issues with the seat bottoms just staying vertical on me. Note, that if you hear a tearing sound when lifting the first one, it's OK. There a fabric flap that spans the seat break and it Velcros to the underside of each bottom.
    12v on driver's side as referenced in the manual. Off gas vacuum tube is attached on the negative post side towards the driver's seat. You'll have the trim tool, and you'll need a 10mm socket for disconnecting the terminal posts.
    There's also a small fuse/relay setup on the passenger side for those interested.
    dleithaus and H2o-Bar like this.
  13. Nov 3, 2024 at 3:28 AM
    #133
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    Whole lot of stuff going on under there
  14. Nov 3, 2024 at 11:35 AM
    #134
    LN13
    LN13 Well-Known Member
    Arizona
    2024 TRD OR Hybrid
    I am reading this thread intently, as I want the hybrid, but a little curious myself, please keep thread alive and give me a reason to choose or not!!
  15. Nov 3, 2024 at 11:47 AM
    #135
    Vidman
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    If you can afford one then go for it….you’ll be smiling all day long
    CJBiggs, vprgts, Scott Zinger and 3 others like this.
  16. Nov 6, 2024 at 8:58 AM
    #136
    Sullivan0930
    Sullivan0930 Well-Known Member
    Daniel
    2024 TRD Offroad. iforce max. Bronze oxide.
    1300 miles and no issues so far. I’m still worried about transmission issues though. I can’t tell if the truck shifts weird or if it’s just the hybrid switching the motors. I’d say it’s definitely not 100% smooth when accelerating from a stop. But maybe it’s all in my head.
  17. Nov 6, 2024 at 9:11 AM
    #137
    sogtr
    i got about 1500 miles and took it off road twice since. Bend my exhaust and it fell off on trail, so had to do a quick fix on a trail. Im also in the same boat for transmission, but i didnt notice any accelerating issues or anything in that sort.
  18. Nov 6, 2024 at 9:25 AM
    #138
    gmtech
    Stock AF
    5200 on mine. just put 3k on it in a week driving to CO and back. no regrets! glad i waited for hybrid! doing 5k oil change and TRD trail exhaust tomorrow!
    enforcertaco91, vprgts and sogtr like this.
  19. Nov 6, 2024 at 10:26 AM
    #139
    dleithaus
    dleithaus Well-Known Member
    Washington State
    2024 TRD OR iForce Max
    Picked up a iForce Max Hybrid yesterday. I drove it a couple of weeks ago, along with a regular non-hybrid version. Initial impressions, definitely wanted the hybrid for 0-30 MPH acceleration, and maybe a bit quieter. Seating is noticeably better than my 2021.
    Backing up a bit, I had an appointment not too far from the dealership and decided to stop in and see what they had on the lot. Two hybrids. I was surprised the one I drove weeks ago was still on the lot (grand total 34 miles on the odometer, no one was even test driving it?). ("Sales kind of slow?" I asked. "We never sell as many as quickly as we would like". Uh yeah, I bet!) So now I am comparing the one with only heated seats as an option vs two upper and full fledged OffRoad option package ($4640) and the other with the Premium option package. (Premium vented seats, moonroof, electric tailgate, digital mirror, JBL front speaker, etc $8800).
    On my old OffRoad 2021 I had a self dimming mirror with Homelink for my garage remote along with a motor adjustable drivers seat. The lower trim 2024 did have the larger screen, heated seats, and an illuminated (essential! :bored:) front emblem. No Homelink on the self dimming mirror, and driver seat with manual 8 way adjustment. For about $10K less than the premium one onsite. $50K vs $60K outside of taxes. The salesperson told me I could wait for something else, but of all the potential hybrid allocations coming in, all the OffRoad hybrid versions had the Premium option pack. He told me that he could try to delete things mid manufacturing. "Really, you can do that?" "Well, not really... but we can try". I purchased my 2021 from this dealer (Marysville Toyota, Marysville WA. MSRP only, even on Pro), so I trusted the sales process, and laughed over trying to change an allocation.
    Considering the options I actually wanted, I think I can just install a smarter Homelink mirror and be good. As I put some miles on the new one I will check back. I do not notice any drivetrain clunkiness during shifting, stopping, or starting from a stop. I have not touched any standard settings (yet).
    Cheers.
    Airborne likes this.
  20. Nov 6, 2024 at 11:27 AM
    #140
    gmtech
    Stock AF
    i just got the regular 4k option package. i didnt want sunroof. stupid camera mirror and auto tailgate. mine did come with homelink mirror on my option package.
    dleithaus likes this.
