Hydramat for Walbro style fuel pumps
Discussion in 'Performance and Tuning' started by Torspd, Jan 11, 2017.
  1. Feb 23, 2020 at 3:04 PM
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pretty certain that the bottom of the bowl, rests/presses against the bottom of the tank.
    Therefore I had though about cutting openings just above the bottom of the bowl, to allow the mat to extend out from.
    Glad you got it though!!!
  2. Mar 23, 2023 at 1:29 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    This setup still working well for you? I had no idea until today that you could fit a Holley hydramat into a stock tank.
    it honestly is fuel cell territory, but, whatever :burnrubber:
  3. Mar 23, 2023 at 8:39 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I have a bigger tank. It’s an LRA from down under. It’s working well so far.
