Hydraulic Bottle Jack / Jack Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by erockintaco, Feb 7, 2019.
  1. Feb 7, 2019 at 12:33 AM
    erockintaco
    erockintaco [OP] Well-Known Member
    ernie
    Italy
    05 Blk Tacoma Dc 4wd
    295 Ridge Grapplers. 2'10's subs.
    Does anyone have one of these? My stock jack doesn't work on my 3 inch lift. I would like a high jack lift but I don't have any armor on my truck to lift it from nor do I plan to put any armor in the near future. My question with this jack is that if it lifts high enough for my truck. I'm thinking about going with the 6 to 20 tons... Just because, if you're lifting 20 tons, I'm sure it's a school bus of some sort. I don't want to purchase it and run into the same situation I'm in. With stock jack I have to carry around a tree stump and I want to eliminate that.
    https://www.amazon.com/Torin-Hydraulic-Bottle-Jack-Capacity/dp/B000234IT4
  2. Feb 7, 2019 at 12:47 AM
    deadpocketss
    deadpocketss Dingus
    Colorado
    '24 Subaru Crosstrek Premium
  3. Feb 7, 2019 at 1:50 AM
    erockintaco
    ernie
    Italy
    Thanks! I appreciate it. Yeah it sorta helps. Don't get the 20 ton, it won't fit under the truck.... but it looks like I'll just be stuck carrying around a few 2x4s. I guess the 4 tons bottle jacks are about the same as the stock Taco jack.
