Hydroclubusa.com
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dvst8r1K, Apr 4, 2022.
  1. Apr 4, 2022 at 11:00 PM
    Dvst8r1K
    Dvst8r1K [OP] Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    just curious if anyone has inside this kit and what was the outcome??
    I'm thinking this is the propane injection kit for gas powered engines.
    Anyone install or have any thoughts on this matter??
    Thanks in advance.
  2. Apr 5, 2022 at 12:23 AM
    TacoTuesday1
    SD CA
    I believe switching to propane injection or something is more common in Europe
    Maybe it’s LPG, liquid petroleum gas
    I don’t know where fillup stations are
    And I believe it requires adding a tank
    I recently saw a video of a CNG car explode from the 2,000 psi tank. Can’t say I want a CNG conversion after seeing that.
    would much rather do a diesel swap. Or better gas engine.
    LPG is probably common in Europe because of “petrol is 10 euro a liter” or whatever
    I doubt they have any of their own natural oil supply from the ground there
  3. Apr 5, 2022 at 1:08 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    What's your goal with adding this system?
    If it was the same video I saw, I believe it was a dual propane/CNG system where CNG was inadvertently being filled into the LPG tank. LPG is stored at much lower pressures than CNG, so when they tried to fill the LPG tank with CNG, it obviously ruptured and exploded. Just for reference, if it was a different vid then disregard.
  4. Apr 5, 2022 at 2:53 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I thought people did propane because of fuel starvation when off-roading and the truck is on some very steep angles causing the fuel pump to suck air.
