Hydrolocked my truck yesterday
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomatrd, Aug 25, 2012.
  1. Aug 25, 2012 at 4:18 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    last and smallest puddle lmao
  2. Aug 25, 2012 at 4:18 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    That probably should a been a warning right there. I mean why would you through big puddles that long?
  3. Aug 25, 2012 at 4:18 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    if the engine hydro locked would the vehicle skid? or would it roll to a stop? you a manny or auto? also when you try to start does the starter sound like its trying or does it click?
  4. Aug 25, 2012 at 4:20 PM
    09tacomatrd
    09tacomatrd [OP] Well-Known Member
    Jeremy
    New Jersey
    09 Tacoma TRD Access Cab
    URD Intake, Aero Turbine 2525 Exhaust, alpine component speakers and 8" ken wood excelon woofer. Powered by 750 watt ken wood amp.
    yup. I actually remembering thinking "ill hit this fast and rinse the truck off and then were outta here..."
  5. Aug 25, 2012 at 4:20 PM
    08pretaco
    az
    HAHA The best ideas sometimes, most of the time, turn out to be the worst.
  6. Aug 25, 2012 at 4:59 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Years ago my friend's wife ran her MB 250SL through deep water the next day Mr came to the shop and took a plug out it was cold over night and there was ice on the spark plug. Long story short one connecting rod was sheared off as if it were cut with a saw. Water does not compress.
  7. Aug 25, 2012 at 5:08 PM
    09tacomatrd
    Jeremy
    New Jersey
    I feel much better thank you.
  8. Aug 25, 2012 at 5:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I just may be hydro-locked if it couldn't even turn the engine over. Can you say bent rods and valve stems...? Hope not but...
  9. Aug 25, 2012 at 5:15 PM
    08pretaco
    az
    thats a little deeper than 10"
  10. Aug 25, 2012 at 5:24 PM
    09tacomatrd
    Jeremy
    New Jersey
  11. Aug 25, 2012 at 5:30 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    White smoke and all?
    Couldn't it just be a wet alternator? Similar thing happened to a friend and it was the alternator.
  12. Aug 25, 2012 at 5:38 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    White smoke might be just steam from hitting the hot engine and manifold.:notsure:
  13. Aug 25, 2012 at 5:40 PM
    09tacomatrd
    Jeremy
    New Jersey
    yes white smoke and all. but im hoping it was steam.
  14. Aug 25, 2012 at 6:50 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    id tell toyota to check here first.... /B]
  15. Aug 25, 2012 at 6:50 PM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
  16. Aug 25, 2012 at 6:56 PM
    #36
    monsterkx2fiddy
    Read his post wrong. It is probably a wet distributor. Id check that first open nd dry out.
  17. Aug 25, 2012 at 7:11 PM
    #37
    JayDirt
    JayDirt I owe it all to little chocolate donuts
  18. Aug 25, 2012 at 11:49 PM
    #38
    joes06tacoma
    Joe
    Central Coast, CA
    I wish you luck man.
    I know two brothers who both have sunk a truck in a local creek. One of them bought an engine. The connecting rods were "S" shaped when he tore the old engine apart. The other brother pulled the plugs, cleaned out the starter, and blew the water out of the cylinders. Started right up, no damage to the engine. Changed all the fluids a few times, pulled the carpet and interior out of the truck to clean it, drove it a couple of weeks, and lost the throwout bearing and a wheel bearing. Swapped those out, ran it another year and the rear diff went out. He thinks it was related to the salt water, had to change the oil several times before it came out clear. Anyway, it's not over till it's over, you're not sunk yet.
  19. Aug 27, 2012 at 8:21 AM
    #39
    shemp
    shemp Well-Known Member
    Hope its just wet electric. An engine replacement would not be fun or inexpensive.
    When you tried to start it after it quit, did the starter motor make a clunking sound like it was engaging the teeth but not going anywhere? Or was it completely unresponsive?
    If waiting or repeatedly operating the starter motor until the engine turned, got it to turn over normally again, then you can be almost certain that it was hydrolocked, and trashed. Hydrolocking doesn't necessarily cause the engine to quit with a bang. Unless the intake pipe is just completely filled with water, each stroke will draw in progressively more water than the last stroke, raising the compression to the point where it is able to tip over the edge and stall the engine. If you're lucky, it is certainly possible to suck water into the engine and have it stall without actually damaging the engine, in this possibility, the water interrupts ignition (spark plug) without hydrolocking, so it will quit softly and will be able to run again once the water has cleared. I had this happen to my ATV once when crossing water that turned out to be deeper than the seat. The airbox didn't completely fill with water, it motored out of the water and stalled out gently on the incline after getting out of the water. After emptying the water out of the airbox and cranking it for several minutes, it fired up and ran like normal. That happened about 10 years ago, and it still runs like the day it came out of the factory.
  20. Aug 27, 2012 at 8:35 AM
    #40
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    just fyi, go slowly through water try not to blast through it like your in an action movie being chased by the police.
    if the puddle was only 10" thats not even factory ground clearance yet you should have been fine so i know you must have hit it at speed. it could be other things ike wet electronics i personally had the truck gone over with dielectric grease and sealant to try and prevent a situation like this. there is a lot that goes into making your truck water resistant.
    i hope its not hydrolocked man good luck and let us know what the dealer has to say.
