Hydrolocked my truck yesterday
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomatrd, Aug 25, 2012.
  1. Aug 28, 2012 at 6:36 AM
    #41
    09tacomatrd
    09tacomatrd [OP] Well-Known Member
    Jeremy
    New Jersey
    09 Tacoma TRD Access Cab
    URD Intake, Aero Turbine 2525 Exhaust, alpine component speakers and 8" ken wood excelon woofer. Powered by 750 watt ken wood amp.
    My truck is on its way to Headmasters to have the engine ripped open and worked on. I couldn't do the warranty route for a variety of reasons not limited to but certainly including its illegal.
  2. Aug 28, 2012 at 6:48 AM
    #42
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I've had water up to my fender flares. That's over 3 feet. Just go sllooowww is the key.
  3. Aug 28, 2012 at 10:14 AM
    #43
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    still think puddles are fun?
    that sucks..good luck. but what does this mean?
    "I couldn't do the warranty route for a variety of reasons not limited to but certainly including its illegal"
  4. Aug 28, 2012 at 10:15 AM
    #44
    Manwithoutaplan
    ID
    :ohsnap:
    It is truck Bridge :D
  5. Aug 28, 2012 at 10:16 AM
    #45
    PhantomVirus
    PhantomVirus Well-Known Member
    Ron
    People's Republic of NJ
    2012 Super White TRD OffRoad Double Cab
    Don't steal my tailgate Mod, Hardwired Valentine1 Radar Detector, Smitty N-FAB Nerf Bars, Led lights (Maps, overhead & rear License Plate), Debadged, TRD rim center covers, Replaced Chrome Grill with OEM Super White, PlastiDipped Toyota Logo on Grill BLACK, Distinct Offroad Custom light bar
    Stupidity is not under warranty?
  6. Aug 28, 2012 at 10:22 AM
    #46
    Rez
    Rez Well-Known Member
    Vancouver BC
    TRD Sport
    I can't see how you hydrolock in 10" puddle, most likely some water got spryed on the electrical parts like coil or spark-plug wire...., where you had some bad wiring and cusing problem there.
  7. Aug 28, 2012 at 10:24 AM
    #47
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Even a snorkel won't save you if you like to try to hydro-plain over puddles. The air ram intake faces forward and will suck up water huge amounts of water if they are spraying upwards. I'm sure the URD did not help one bit, but pretty sure this issues is unavoidable when doing ridiculous speeds over puddles. This story could of had a real bad ending should OP of hit a log, deep hole, or anything else lurking in puddles. Just be glad you didn't get hurt and hopefully some other members will read this and slow down so some good will come out of your experience.
    Correct speed for puddle hopping
  8. Aug 28, 2012 at 10:51 AM
    #48
    09tacomatrd
    Jeremy
    New Jersey
    Turned the engine manually with a wrench and it stopped like it hit something. We think theres a broke piston and possibly some other odds and ends. I'll keep you all posted.
    Its not that hard to hydrolock an engine when the URD CAI is right in front of the radiator. Lesson learned...
  9. Aug 28, 2012 at 11:07 AM
    #49
    BamaToy1997
    Bill
    Navarre, FL
    Really that depends on the amount of water. You can hydrolock an engine withe less than a coffee cup's worth of water if it is drawn in at the right time. The combustion cylinder of most engines is between 50 and 100cc of fluid. Exceed that fluid by ANY amount, and you will hydrolock, and possibly damage your engine.
    Did you remove the spark plugs before you did this? If you are hydrolocked, then it will react just like that until you clear out the water. Water is NOT compressible.
  10. Aug 28, 2012 at 11:09 AM
    #50
    XXXX
    sKiP
    05 Prius
    I didn't even notice the location. He should of broke his cherry out with us then he would have another 3k in his pocket.
    Also curious of puddle. It was dry as hell on the trails this last weekend.
  11. Aug 28, 2012 at 11:15 AM
    #51
    09tacomatrd
    Jeremy
    New Jersey
    Mahwah
    I'll have my truck back in 2 weeks then i'd love to join you.
  12. Aug 28, 2012 at 11:56 AM
    #52
    shemp
    shemp Well-Known Member
    Of course. If you hydrolock in any condition where there is enough inertia to exceed the tolerances of the components, then you have a recipe for damage. If there is NOT enough inertia to exceed the component tolerances though, then there should be no damage.
    So, if you have a 50 cc combustion chamber and run it up to 35 cc of water, that water may be enough to drown the spark, the engine will slow, and for the next stroke, there is less inertia, so when you draw in 55 cc and it hydrolocks, it does do gently and hopefully without damage.
    Of course if you draw in a full cylinder of water while spinning 4000 rpm, you're looking at a rather large chunk of scrap metal.
    Technically speaking, water is compressible, but only very slightly and under extreme pressures. However you are correct that you can think of it as being non-compressible since it is negligible under these conditions. 40 MPa ~1.8% volume reduction. That's under the weight of 4 km of water.
  13. Aug 28, 2012 at 8:40 PM
    #53
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    :brianr:
    Bad idea? Probably! Couldn't resist, but it turned out fine.
    Did get my filter wet a few weeks ago washing the truck with the garden hose. Started acting a little funny at high RPMs, guess that's when it was sucking water the most. Whoops.
  14. Aug 28, 2012 at 8:46 PM
    #54
    Spoonman
    Jamie
    Alberta
    Turn your snorkel head backwards? Then go through puddles at 200.
  15. Aug 29, 2012 at 5:36 AM
    #55
    BamaToy1997
    Bill
    Navarre, FL
    First, I simply said if you drew in more than the CC of the combustion chamber, you would hydrolock and possibly damage the engine. I never said it WOULD. Second, when it comes to hydrolocking an automotive engine, you can pretty much consider water is not compressible. The compression of water is so infinitesimal that it is essentially zero. No need to get the physics book out for this situation. :D
  16. Aug 29, 2012 at 1:09 PM
    #56
    shemp
    Duh, which is why I agreed in some places and CLARIFIED in others.
  17. Aug 29, 2012 at 3:59 PM
    #57
    XXXX
    sKiP
    05 Prius
    Our trails have holes that swallow full size lifted trucks so I go in slow at all times unless I'm following a speed demon on the trail and even then I slam on the brakes before the hole. Also cleaning mud water in the cab gets old after a while :eek:
    So all I need to do to get up to 200 is turn it backwards
    :yay:
  18. Aug 29, 2012 at 4:32 PM
    #58
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    OP, sorry for your loss.
    ROFL @ this snorkel discussion. If I ever have one I'll install it backwards for laughs. :laugh:
  19. Aug 29, 2012 at 4:57 PM
    #59
    PhantomVirus
    Ron
    Bama please NEVER change your signature.
  20. Aug 30, 2012 at 5:39 AM
    #60
    BamaToy1997
    Bill
    Navarre, FL
    LMAO, I honestly don't intend to unless I find a better GIF. I have gotten more comments on this gif than I can remember. It seems pretty popular. (Probably doesn't hurt that she resembles Tara Reid either!)
