Hydrolocked my truck yesterday
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomatrd, Aug 25, 2012.
  1. Mar 26, 2013 at 1:53 PM
    #61
    13Tacoma
    13Tacoma Well-Known Member
    Colorado
    2013 TRD Off-Road Silver Streak DC
    Fog Light Mod, Debadged Tailgate, Blacked out Front Grill, Removed Front Mud Flaps, 3" Lift, 4" Quantum LED's mounted behind Lower Valence-Courtesy of Kmd Garage Group Buy.
    I would have to agree. It only takes a very small amount of water. My buddy had a 93' Mustang with a ram air that sat just under the front valence and hydrolocked his motor coming out of McDonalds in a small puddle. He was pissed!..
  2. Mar 26, 2013 at 1:58 PM
    #62
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    That's what you get for chowing at Mac and Don's steak house! ^
    @ OP, sorry to have to read all this!
  3. Mar 26, 2013 at 2:06 PM
    #63
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    Know this is old thread.. but that still sucks.
    Reason I don't have a CAI
  4. Mar 27, 2013 at 5:44 AM
    #64
    Eman1234
    Eman1234 Active Member
    Erik
    Man that sucks bro praying your truck turns out ok and it was something else.. Does the urd filter covers protect against this at all??
  5. Mar 27, 2013 at 5:50 AM
    #65
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    09tacomatrd is offline
    Last Activity: 10-12-2012 09:52 AM
  6. Mar 28, 2013 at 6:25 AM
    #66
    09tacomatrd
    09tacomatrd [OP] Well-Known Member
    Jeremy
    New Jersey
    09 Tacoma TRD Access Cab
    URD Intake, Aero Turbine 2525 Exhaust, alpine component speakers and 8" ken wood excelon woofer. Powered by 750 watt ken wood amp.
    Thanks. I wound up paying $3500 to have the engine repaired. Urd does not cover it.
  7. Mar 28, 2013 at 7:45 AM
    #67
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    NOTE: to anyone watching
    a non-fatal hydrolock can occur more often than a sudden hydrolock
    You might get just enough over-compression from a small hydrolock to slightly damage the
    wrist-pin or bearing shells on the crankshaft...and over time this will eat away
    at itself and cause a later failure...10,000 miles later or whatever...oil analysis should
    reveal increased metals should you fear that you might have sucked in water and 'Whew! I got away
    with that one...'
    ...maybe you didn't really get away with it...oil analysis x2 is what to do next if you think you came close.
    if it is going to blow up later metals will increase over time
  8. Mar 28, 2013 at 8:04 AM
    #68
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Or... when you water crossing keep your engine RPM's low. Best to idle through. Put on 4L and let truck roll through, and if you need to give it gas keep it under 1000 RPM's.
  9. Mar 28, 2013 at 8:26 AM
    #69
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Let me mention that a few CAI's come with a protective splash shroud that works pretty good. If you use the rubber edging that they come with, you can get a pretty good defense against big splashes from high speed puddle crossings. I'm not saying they're ideal, but some are designed right.
    An exposed CAI filter is very vulnerable though. That's just asking for trouble.
  10. Mar 28, 2013 at 7:12 PM
    #70
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    Likewise for the unnecessary "brake booster hose" application of Seafoam.
  11. Mar 28, 2013 at 10:53 PM
    #71
    Duartizzle
    Duartizzle Well-Known Member
    Huntington Beach, CA
    Double Cab 4x4 TRD Off-Road
    I hydrolocked a 93 4runner a few years ago doing the same thing as OP. Puddle maybe went as high as halfway up my wheel. I went blasting through and truck died. Had to get towed out and an engine rebuild (thankfully the 3.slo motor was only 1600 to repair) the lesson learned was there is no need to blast through puddles unless you like ruining motors.
  12. Mar 31, 2013 at 11:04 AM
    #72
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Im staring at my urd intake and wondering if I'm going to install it after reading this thread. Have the cover for it, but....
  13. Mar 31, 2013 at 11:20 AM
    #73
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Just go slow and you'll never need a snorkel. Unless it's deep enough, then you can get into trouble anyway.
  14. Mar 31, 2013 at 11:29 AM
    #74
    SoCalTacos
    socal
    I'm more worried about car washes...from what I'm reading I would run a risk just by washing this thing.
  15. Mar 31, 2013 at 12:19 PM
    #75
    Spoonman
    Jamie
    Alberta
    Don't spray the filter and you'll be fine^^
  16. Mar 31, 2013 at 12:40 PM
    #76
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    ill gladly take it off your hands!!
  17. Mar 31, 2013 at 2:25 PM
    #77
    SoCalTacos
    socal
    I'll keep you posted
