Hydrolocked??
Discussion in '1st Gen. Tacomas (1995-2004)' started by spazoner, Aug 30, 2010.
  1. Aug 30, 2010 at 10:22 PM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    98 Tacoma Xtra Cab Limited
    4" ProComp Lift, Volant Intake, ProComp Wheel/Tire Combo
    (1998 Tacoma V6 four cam) Ok so Im pretty sure there's a couple threads on this already but i couldn't find a solution to my problem.
    Here's the story, went through "puddle" and in the middle got deeper on passenger side and died. No water in cab, But took water into intake. Let dry for a couple hours. Pulled spark plugs and looked into the cylinders saw water in two of them. So obviously tried to turn the engine over to get the water out, but all i got was a ticking sound, (Such as a dead battery tick) Charged battery but still getting same outcome. Checked fuses, relays, and as many electrical components as possible. Starter problems maybe? Still any advice or ideas would be helpful. Thanks.
  2. Aug 30, 2010 at 10:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did you remove all of the spark plugs before trying to turn it over? If not and one of the cylinders is full of water it could be locked. :(
  3. Aug 30, 2010 at 10:57 PM
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    Ouch! that sucks man.
  4. Aug 30, 2010 at 11:24 PM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    I had a dodge neon that had the same issue, went through too much water when a city storm drain was plugged. Died, had it towed home took the plugs out and saw water in the cylinders. After hearing the ticking sound I continued to try and roll the motor over and BANG! A piston slammed through the oil pan and covered my shop floor with 4 quarts of oil. If I had drained the oil pan (which contained water and oil), perhaps the piston wouldn't have been thrown through the pan, dunno. The motor had experienced irreversible damage prior to me taking the plugs out, hopefully you have an easier experience.
    Aaron
  5. Aug 31, 2010 at 12:42 AM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    after it happened i did try turning it over while still in the water but just got the tickin noise. So far my attention draws to the starter and battery. Possible short maybe or plug with water in it. Or the solenoid on the starter. Am i wrong by thinkin that?
  6. Aug 31, 2010 at 1:50 AM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    if you turned it over after it died, it may be too late and hydrolocked
  7. Aug 31, 2010 at 4:02 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I would drain the oil and pull all plugs. crank the engine over by hand with the plugs out and see if any water comes out...
  8. Aug 31, 2010 at 5:26 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Agreed.
  9. Aug 31, 2010 at 5:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like a bad starter solenoid. They don't like water either.
  10. Aug 31, 2010 at 5:50 AM
    Kuneff
    Kuneff Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I would also even get you some straws from McD's and put them into the spark plug holes. Make sure they are going up and down with the pistons when you manually turn the engine over. Sounds dumb, but it works. Thats how we figured out my friend hydrolocked his civic. Snapped a rod in half.
  11. Aug 31, 2010 at 9:10 AM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    thanks guys. turning it by hand is the next step after i check the solenoid.
  12. Aug 31, 2010 at 11:25 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Ya it sounds like something to do with the starter got wet and is not working right anymore. And if it is making the same sound that they do when the batterys dead then I would be almost sure thats what it is.
  13. Aug 31, 2010 at 6:57 PM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    ok so we turned the motor by hand and then i tried turning it over with the key, shot water out of some cylinders then stopped. seems to stop at the same place everytime we tried. im taking the oil pan off tomorrow to check for rods. idk but im starting to think shits gettin worse. =/ but thanks for all the advice guys
  14. Sep 7, 2010 at 7:27 PM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    thrown rod... =[
  15. Sep 7, 2010 at 7:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Ouch bro- Good luck with the repairs...
  16. Sep 7, 2010 at 7:39 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    gonna rebuild it or replace it?
  17. Sep 8, 2010 at 12:42 AM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    Brunes = thanks man..
    98MudBug = replace it prob. dont have the cash to build it. although i have been dreamin about that haha.. if i do anything its goin to be the lift ive been waitin for and im thinkin about line-xing the whole body. snorkel, waterproofing everything possible and some other exterior mods..
  18. Sep 8, 2010 at 4:34 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Happened to a friend of mine with his Chevy K10 (Chevy 350 block). We used a wet vac and using tape, we taped of the end of the hose (with a small opening so the vac doesnt overheat) and attached a long straw to the end. We removed the plugs, vacuumed out the cylinders, poured a bit of oil down each cylinder and cranked by hand. Once we finished, we reassembled, changed the oil, poured seafoam into the oil sump, and turned her over. She fired up and ran rough for about an hour. Once she settled out, we did another oil change and she's been running just fine since (~6 years ago).
  19. Sep 8, 2010 at 4:42 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    that sucks good luck
    stay out of the water
  20. Sep 9, 2010 at 5:55 AM
    spazoner
    spazoner [OP] 303
    Thomas
    Fort Riley, Kansas
    _ i wish my ending could have been like this lol. broke a rod. =/
    @brutalguyracing - lol good idea
