Hylux VS Morimoto VS Xenon Depot HID Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SLACKBOY, Feb 17, 2018.
Hylux VS Morimoto VS Xenon Depot Xtreme HID Kit
  1. Hylux HID Kit
    25 vote(s)
    18.7%
  2. Morimoto HID Kit
    54 vote(s)
    40.3%
  3. Xenon Depot Extreme HID Kit
    55 vote(s)
    41.0%
  1. Feb 27, 2018 at 6:31 PM
    #41
    Scruffie
    Scruffie Well-Known Member
    Arsie
    Surrey B.C Canada
    2016 QuickSand Access TRD OR Manual
    265/75/16Dura,SSO Hybrid,X20,CruisinSliders,Skids
    X2 ^^^^^ Couldn't agree more. Same setup. About the same amount of time/milage and the lights have, and continue to performed excellent!!!!
    Vbpiper and su.b.rat[QUOTED] like this.
  2. Feb 27, 2018 at 7:21 PM
    #42
    SLACKBOY
    SLACKBOY [OP] Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Try it now sir !
    su.b.rat[QUOTED] likes this.
  3. Feb 27, 2018 at 7:22 PM
    #43
    SLACKBOY
    Erich
    Washington State
    I have re opened the voting portion ! Please cast your vote!
  4. Feb 27, 2018 at 7:53 PM
    #44
    coarsegold1
    coarsegold1 Well-Known Member
    So, please disregard if this hijacks in any way. I too was considering XenonDepot's 4300K HID Kit for my '18 Tacoma and after going onto their site to verify fitment, etc., I couldn't find the '18. I contacted the vendor and Danny replied with "Unfortunately, we don't have the lighting data for the 2018 Tacoma yet so you'll need to double check with your truck to confirm what you need." Leaves me pretty uncertain on exactly what I need for Plug-N-Play, especially when we are talking $300+. Left with more questions than answers...
  5. Feb 27, 2018 at 8:29 PM
    #45
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    I
    I think it's h11b?
  6. Feb 28, 2018 at 6:39 AM
    #46
    SLACKBOY
    Erich
    Washington State
  7. Feb 28, 2018 at 9:38 AM
    #47
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I have the morimoto 50W 6500Ks. They are very nice but they do shake. I've done a good bit of testing/looking into it. My conclusion is it's the seating of the bulb in the projector that creates the shake. The looser this is the more shake you get. I'm on the original gaskets so I suspect getting the HD gaskets Morimoto was sending out would help but I think there's two other things that play a roll in the 50W morimotos getting reported with shake more so than others...
    Heat and output. The heat makes the gaskets softer so that allows more shake. The higher output makes the shake more visible. There's no way you would be able to see the shake with the OEM halogens even if it were there. Just not enough output. Further, the morimoto's do have "hot beams" if you will that make it more noticeable imo. The output is not 100% uniform as you can see the main beams coming from both sides and meeting in the middle.
    Also, it does depend where you drive. The shake is not noticeable in town on lit streets. Nor will there be any shake on highways/interstates. Where you see the shake is at moderate speeds, in very low light situations on very rough roads. Think a dirt road out in the country where your headlights are the only lights around.
    I've considered swapping in the xenon depot phillips bulbs but someone did exactly this and reported worse shake after the swap so I've held off...it's possible it comes down to the tolerance of your projector socket. If it's a little bigger than others maybe you get shake with any bulb you throw in there.
  8. Feb 28, 2018 at 2:01 PM
    #48
    XenonDepot
    XenonDepot Well-Known Member Vendor
    If we don't have the listing in our fitment guide and you are not sure which ones you need, you can check with your Owner's Manual, or inspect the bulbs in the vehicle to be 100% sure of the information. When checking in the vehicle, you do not always need to go as far as pulling out a bulb to check - most vehicles have the bulb type written/etched on the front of the headlight lens somewhere. Take a look at the front of your vehicle and you can probably find what you need.
    That being said, the 2017 Tacomas use H11 bulbs for the Low Beams and the 2018s are also part of the same manufacturing generation, so they are most likely the same. Best to double-check to be sure, though.
    ~Robert
  9. Feb 28, 2018 at 2:33 PM
    #49
    SLACKBOY
    Erich
    Washington State
    Thanks Robert! That’s great info !
    XenonDepot[QUOTED] likes this.
  10. May 2, 2018 at 4:38 PM
    #50
    Guntaco
    Guntaco Well-Known Member
    2017 TRD Offroad
    Are you running stock fog bulbs with the Laminex. I tried some knock off yellow film and with the stock fog light it just looked gross lol.
  11. May 2, 2018 at 5:56 PM
    #51
    SeeWhatHadHappenedWas...
    SeeWhatHadHappenedWas... Well-Known Member
    Jeremiah
    Oregon
    2017 OR DCSB MT Quicksand
    How bright do lights need to be for just running around in a city. I think the stock lights are really bright. There is street lights, there is other cars with lights. I mean if you feel the need to blind people just use a 30 or 40 inch light bar and drive around with that on. I put BD squadron pros in the fogs so I can play light battle too. You may not see me with your bright ass lights shining but if you have blinding lights I’m flipping you off every time.
  12. May 2, 2018 at 7:59 PM
    #52
    Guntaco
    2017 TRD Offroad
    :stirthepot: Someone sounds salty.
  13. May 3, 2018 at 6:27 AM
    #53
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    I have the Profile kit in my truck. Works great, no shake.
  14. May 3, 2018 at 2:02 PM
    #54
    bbrown
    bbrown Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    I am running the TRS Morimoto XB LED's. Here is my post from the Group Buy TRS Group Buy: Morimoto XB LED Fog Lights
  15. May 3, 2018 at 2:30 PM
    #55
    GoodOlBoy
    GoodOlBoy Well-Known Member
    Brennan
    2016 MGM TRDOR
    I have the Morimoto kit. I’ve been running them for over two years now and really love them. I got the 55 watt ballasts. They really light up the road. It’s a huuuuuge difference from the factory bulbs the truck came with. All this said, it is the first HIDs I’ve ever had so no comparisons there. I just know these have been great for me
  16. May 3, 2018 at 6:06 PM
    #56
    Guntaco
    2017 TRD Offroad
    Was for the guy above you who was complaining about people using hid.
    Vbpiper likes this.
  17. May 3, 2018 at 7:35 PM
    #57
    SQR74
    SQR74 Well-Known Member
    Austin, TX
    2018 Tacoma TRD Sport
    I have been using Hylux fast bright HID ballasts for over a year. Not disappointed.
  18. May 3, 2018 at 9:45 PM
    #58
    spiros1
    spiros1 Well-Known Member
    tung
    2017 trd sport double cap inferno
    pro grill, moonroof, plastidip flares
    I’m a newbie trying to get a hid kit for my truck but idk what should i go with? Is it easy to install ? I watched many clips on utube but still confused.
  19. May 8, 2018 at 11:13 AM
    #59
    XenonDepot
    @spiros1 - Feel free to give us a call toll free @ 1-877-522-2701, we'd be happy to help any answers you may have.
    @Vbpiper - Thank you for your support :)
    Vbpiper likes this.
  20. Oct 25, 2018 at 8:01 AM
    #60
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
    Where did you get this "Tacoma HD bulb seal" ?
    I just installed the XD HID and was told the HID bounce is "normal" . Yea, not when I paid $180 for a HID kit with the Philips bulb. I guess I'll have to fix this issue myself.
