Hylux VS Morimoto VS Xenon Depot HID Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SLACKBOY, Feb 17, 2018.
Hylux VS Morimoto VS Xenon Depot Xtreme HID Kit
  1. Hylux HID Kit
    25 vote(s)
    18.7%
  2. Morimoto HID Kit
    54 vote(s)
    40.3%
  3. Xenon Depot Extreme HID Kit
    55 vote(s)
    41.0%
  1. Oct 25, 2018 at 5:45 PM
    #61
    bbrown
    bbrown Well-Known Member
    Buster
    Geauga County Ohio
    '17 Super White TRD-OR DCSB 6-SPD
    255/85R16 ST MAXX
    @TurnLeft The bulb seals were included in the TRS 2016+ Tacoma specific Morimoto kits. https://www.theretrofitsource.com/2...Toyota+Tacoma&preselect=&preselect_restrict=1
    I don't see them specifically called out on the website, but here is the description of the seals from my January 2017 order confirmation email:
    Tacoma-HD Bulb Seals
    2 x Higher-Density H11 Bulb Grommet
    Part Number: SP280
    The seals are also referenced in the Morimoto master thread:Morimoto Elite HID System and LED Fogs for your '16+ Tacoma
    TurnLeft likes this.
  2. Oct 26, 2018 at 6:07 PM
    #62
    mahlogic
    mahlogic Member
    Miguel
    Northern Philly
    2018 Tacoma TRD Pro
    none (yet)
    I installed Morimotos a couple of weeks ago. The lighting, cutoff, coverage and throw are great, but they are very shaky, even in somewhat smooth roads. Has someone tried different bulbs with the Morimoto ballasts and relays? Are the connectors universal? what brand bulb have you installed and where did you buy them? THanks!
  3. Oct 26, 2018 at 9:33 PM
    #63
    Tacoma2020
    Tacoma2020 Well-Known Member
    You bought https://www.xenondepot.com/H11-HID-Kit-Xtreme-HID-p/xt-h11.htm ?
  4. Oct 26, 2018 at 9:34 PM
    #64
    Tacoma2020
    What exactly did you buy?
  5. Oct 26, 2018 at 10:34 PM
    #65
    I jumped on a set of morimoto 4500k 35w HID set when ebay was running their coupon. Ill probably get it and have it installed in a week. I will post pics if I do and comment if I have any shake.
    #65
  6. Oct 27, 2018 at 6:52 AM
    #66
    jeffthedude
    jeffthedude Well-Known Member
    Orlando, FL
    2017 Taco TRD O/R 4x4
    I have the Xenon Depot Philips 4300K kit and they shake and bounce like crazy. Whats strange is they didn't do this in the beginning and have been in the truck since January. I have tried swapping the factory bulb o-rings over to them which made no difference. Xenon Depot is aware of the problem and is ordering some thicker o-rings for people to try whenever they get in stock. Hopefully it fixes it, i'm going back to the stock halogen until then. I spent about 4 hrs last night driving some back roads and its about the most annoying/distracting thing to see bouncing light in front of you with every little bump you hit.
    Technique likes this.
  7. Oct 27, 2018 at 7:51 AM
    #67
    bbrown
    Buster
    Geauga County Ohio
    255/85R16 ST MAXX
    My Morimoto's from TRS and the heavy duty Tacoma grommets on the bulbs have been bounce free. I have had mine installed since January 2017. The bulbs are super tight in the factory projector housing. I have the 6500k bulbs with 50 W ballests - that may be part of it.
  8. Oct 27, 2018 at 1:00 PM
    #68
    mahlogic
    mahlogic Member
    Miguel
    Northern Philly
    2018 Tacoma TRD Pro
    none (yet)
    this is what i bought..
    016+ Tacoma: Morimoto Elite HS-TACOMA 1
    HID Ballasts
    2 x 35w / AMP: Morimoto XB Ballast BL11
    HID Bulbs
    2 x H11B / H9 / H8: XB 5500K B351
    Wire Harness
    1 x HD Relay: H11/H9/H8/880 H40
    Harness Extension
    1 x 9006 Extension Cord H310
  9. Oct 27, 2018 at 1:58 PM
    #69
    bbrown
    Buster
    Geauga County Ohio
    255/85R16 ST MAXX
    Hmmm... I got the grommets back when I ordered mine. When did you get yours? I didn't get the Harness Extension, is that part of the package now?
    Here is what was on my invoice back in January 2017:
    ORDER ITEMS:
    Item
    Sku Qty
    2016+ Tacoma: Morimoto Elite
    HS-TACOMA 1
    HID Ballasts
    2 x 50w / AMP: Morimoto XB Ballast BL21
    HID Bulbs
    2 x H11B/H9/H8: XB 6500K B360
    2 x Higher-Density H11 Bulb Grommet SP280
    Wire Harness
  10. Oct 27, 2018 at 4:24 PM
    #70
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    This is what I got a month ago too. Barely any shake and great output.
  11. Oct 28, 2018 at 10:33 AM
    #71
    mahlogic
    mahlogic Member
    Miguel
    Northern Philly
    2018 Tacoma TRD Pro
    none (yet)
    I got it last month. Morimoto changed the plastic links of the bulbs, made them a bit more rigid. Ye, the extension is now part of the package, but not necessarily needed if depending on where you install the ballasts and relays.
  12. Oct 28, 2018 at 6:22 PM
    #72
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
  13. Oct 28, 2018 at 7:10 PM
    #73
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Anyone having any long term issues with 50 or 55W bulbs/ballasts? I'll be buying some next month and have always used 35W without issue.
  14. Nov 22, 2018 at 9:33 AM
    #74
    mbae
    mbae Well-Known Member
    Baltimore, MD
    2019 Cement Tacoma TRD Off Road
    Im also curious about the diff between the 35w and 50w morimoto ballasts. Anyone have shaking issues with the 35w? Seems most people reporting the shake have the 50w.
  15. Nov 22, 2018 at 10:15 AM
    #75
    elduder
    Van WA
    That shouldnt matter, the bulbs are the same with either kit. The ballasts change but Morimoto supplies both kits with the same 35w bulbs.
  16. Nov 23, 2018 at 2:52 PM
    #76
    calvinx408
    calvinx408 Active Member
    Calvin
    2018 silver tacoma trd
    did xenotdepot ever came out a fix for this? I just wanted to know since they have a sale today. Thank you for the info
  17. Nov 25, 2018 at 7:54 AM
    #77
    jeffthedude
    Orlando, FL
    Not that i know of, some people are lucky and their 4300k kit doesn't shake. Mine did, so did a decent amount of other members. I switched to Xenon Depot 5000k hids over a week ago. I have zero bounce with them, seems like no does. Spent a good amount of time driving with them at night this past week visiting family in Charlotte.
    calvinx408[QUOTED] likes this.
  18. Nov 25, 2018 at 11:00 AM
    #78
    hewinutah
    hewinutah Well-Known Member
    Utah
    Removed badges/stickers, Heritage Grill
    I went with the Xeondepot 4300K Phillips version in Sept 2018. No issues, great light etc
  19. Dec 2, 2018 at 12:06 PM
    #79
    eraser
    eraser Well-Known Member
    Vancouver Island, BC
    2017 TRD OR
    I have both the TRS morimoto kit and the xenondepot, both shake like crazy. Would consider something else.
  20. Dec 2, 2018 at 12:35 PM
    #80
    calvinx408
    Calvin
    thanks for the info. did you try putting the stock bulbs to see if it stop bouncing?
