Hyper flash without LED bulbs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdmstuff, Oct 28, 2020.
  1. Oct 28, 2020 at 11:37 PM
    jdmstuff
    jdmstuff [OP] Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    I'm getting hyper flash from the driver side lights but I don't have any LED bulbs in my truck. Would replacing the flasher relay help solve this? The passenger side acts normally. I've checked all the bulbs and they are fine. I even swapped them from the driver side to the passenger side but the driver side lights still flash as though there's a burnt out bulb. All of the lights work fine and flash evenly when the hazards are on. I'm not sure where else to look other than the flasher relay, but isn't it only one relay that controls both sides?
  2. Oct 28, 2020 at 11:50 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Which bulbs did you swap?
  3. Oct 28, 2020 at 11:51 PM
    jdmstuff
    Derrick
    All of them except the headlight bulbs. I even went so far as to swap the reverse bulbs even though it has nothing to do with it.
  4. Oct 28, 2020 at 11:52 PM
    Asianguywithatruk
    CenCal
    05 taco DCSB
    Tail lights too?
  5. Oct 28, 2020 at 11:54 PM
    jdmstuff
    Derrick
    Yes, all of the tail lights, the front turn signals, and the front corner marker bulbs.
  6. Oct 29, 2020 at 12:22 AM
    Asianguywithatruk
    CenCal
    05 taco DCSB
    The relay would be the next thing I would check. It’s cheap around $10.
    Actually I would check resistance of all the sockets to make sure there’s no high readings then I would check out the relay.
  7. Oct 29, 2020 at 1:12 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    If you changed the bulbs side to side and the problem stays on the one side, I'd say you have a wiring issue.
    Do you have trailer wiring?
  8. Oct 29, 2020 at 5:13 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    since your Tacoma is a 2018, is it still under warranty?
  9. Oct 29, 2020 at 5:18 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I believe OP has an 08’ as well.
    I am inclined to agree. The circuit should be load sensing. At least that how I understand it. Evidently the current isn’t within the desired range?
    Maybe check the Grounds and bulb sockets for good contact.
  10. Oct 29, 2020 at 10:41 AM
    Hendrix834
    Hendrix834 Land Cruiser Trapped in a Tacoma's Body
    Will
    Memphis, TN
    2014 Silver Tacoma DCSB 4wd
    ^^^This. My trailer wiring was pretty messy on my Landcruiser. It would short and cause all kinds of weird problems until I finally realized it was the issue and fixed it. The fact that it's flashing at all tells me the relay isn't the issue.
  11. Oct 29, 2020 at 12:32 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree with the others. You have a resistance issue in the wiring or more likely one of the sockets on the problem side.
    This could help understand what is happening. A guide for hyperflashing without LED Bulbs...
    https://carpassionate.com/how-to-fix-turn-signals-blinking-fast/
    There is also a troubleshooting guide at the end of the article.
    TnShooter likes this.
  12. Oct 29, 2020 at 7:28 PM
    jdmstuff
    Derrick
    Yes, there's trailer wiring. I just got the truck, and it looks pretty bad. I haven't had a chance to look under there yet. Is there just a connector that I can unhook, or is it hardwired into the harness?
    It's on my '08. No such problems on my '18 or '03 :D
    Thanks, I'll check it out!
  13. Oct 30, 2020 at 1:15 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm not sure how it's wired into your truck. Is it factory trailer wiring or aftermarket? I would say find the easiest spot to disconnect it from the truck to see if your problem goes away.
  14. Oct 30, 2020 at 12:55 PM
    jdmstuff
    Derrick
    It looks like the stock hitch and wiring. I’ll have to climb down there this weekend and check it out
  15. Oct 30, 2020 at 1:13 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    I run LEDs in my DTRL and after much deliberation decided to just live with hyperflashing. It’s not that bad and I’ve passed inspection multiple times since. I wasn’t about to run the stock hot as hell lights and ruin another set of housings.
  16. Oct 30, 2020 at 1:13 PM
    Muddinfun
    Muddinfun Well-Known Member
    I would find it very hard to believe that the towing wiring could be causing the problem. 1st of all, the lights hyperflash because of high resistance/ low current draw. It’s only possible for the towing harness wiring to add more current draw.
    2nd, I’m pretty sure the tow turn signal power is supplied by a tow fuse. The flasher only supplies a signal to the converter box.
  17. Oct 30, 2020 at 1:53 PM
    Muddinfun
    It makes you look like an idiot that bought LEDs at Autozone and was too stupid or too lazy to fix the hyperflash.
    I say it everyday. “Look at that idiot with the hyperflashing turn signals. He’s probably 1 of those people that put in LED headlights because he thought it would be a lighting improvement and now he’s blinding the Hell out of everybody.”
    DaveB.inVa and Jimmyh like this.
  18. Nov 1, 2020 at 12:38 PM
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Opinions abound on the internet. I chose not to go the resistor route and didn’t stick with stock due to the damaging effect to headlight housings. They look great and are a legitimate option for those that don’t want to install resistors.
