Hyperblink after removing led switchback mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by cadman33619, Nov 29, 2013.
  1. Nov 29, 2013 at 11:45 AM
    cadman33619
    cadman33619 [OP] Well-Known Member
    I decided to do away with my LED switchback mod because one of the LEDs went bad. I disconnected the voltage regulator and reinstalled the original amber signal light bulbs. Now only the drivers side signal light blinks normally. The passenger side blinks...but I'm getting the hyperlink.
    What could be causing the hyperlink? It should be back to normal now that I disconnected the voltage regulator and
    LEDs .....correct?
    What I would like is to have them always on (when the car is on) and still flash normally when I use the signal lights. Is that possible?
    Thanks in advance
