Hyperflashing out of nowhere
Discussion in 'Lighting' started by Hogbaseball06, Jul 3, 2022.
  1. Jul 3, 2022 at 7:28 AM
    Hogbaseball06
    Hogbaseball06 [OP] Well-Known Member
    2021 Cement Trail Ed.
    Welcome to my Tacoma Talk, I have a '21 w/ v5 meso turn signals, meso TT stage 1's and custom headlights w/ rx350 ballasts and LED DRL's. I have had no hyperflashing since install of all of these components, and have not adding anything new to my truck recently. 2 days ago I began experiencing hyperflashing when my driver's side turn signal comes on. All of my turn signals work EXCEPT for the drivers side v5 turn signal it goes out when I turn on the drivers side turn signal. On another note, all signals work when I turn the hazard lighs on and function properly.
    Any ideas on what is causing this? TIA
  2. Jul 3, 2022 at 7:30 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Sounds like you have a problematic V5.
    i would swap the stocker mirror signal back in and see what happens.
    Hogbaseball06[OP] likes this.
  3. Jul 3, 2022 at 7:52 AM
    Hogbaseball06
    Tried that still hyper flashing. With the stock turn signal installed though it lights up when hyper flashing (v5 wouldn't light up during hyper flash)
  4. Jul 3, 2022 at 7:56 AM
    BLtheP
    Plano, TX
    That is bizarre for sure. What turn signal do you have installed up front? Bulb? LED?
  5. Jul 3, 2022 at 7:58 AM
    Hogbaseball06
    rx350 ballasts w/ osram HID bulbs if I remember correctly
  6. Jul 3, 2022 at 8:09 AM
    BLtheP
    Plano, TX
    For turn signals?
  7. Jul 3, 2022 at 8:11 AM
    Hogbaseball06
    Sorry I misread that. They are LED. DD or morimoto I can't remember
