Hypertech install and setup
Discussion in '3rd Gen. Tacomas (2016-2023)' started by roth_nj, Jan 1, 2017.
  1. Jan 1, 2017 at 1:05 PM
    roth_nj
    roth_nj [OP] Well-Known Member
    2017 DCLB trd off-road bbp
    Just got the hypertech in. Still waiting on the new rims.
    The install seems super easy on the 3rd gens. I have a question about the computer set up.
    Even though all the pictures showed the model with the display and key inputs, this is just a blank box. Do you hook it up to the computer ahead of installation and set the parameters? Or do you install the unit, and program it while in the truck?
  2. Jan 1, 2017 at 1:12 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Set-up on PC first, set parameters, then install in truck.
  3. Jan 3, 2017 at 7:36 AM
    roth_nj
    set up was pretty quick and easy... just had to go to the website for software because computers don't use CD's anymore....
    does it work good enough using the P sizes or is it better to go and measure the actual height of the new and old tires?
  4. Jan 12, 2017 at 4:55 PM
    fiveofun
    fiveofun Active Member
    Kevin
    2017 TRD ORDC 4X4 Quicksand
    Stock
    I'd like to know if this corrects both the analog and digital speedometers. I'm guessing both, but would just like to confirm.
