Hypertech Speedo Calibrator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Idaman, Jan 6, 2019.
  1. Jan 6, 2019 at 7:43 AM
    Idaman
    Idaman [OP] Member
    Jim
    2016 Fire Blue Pearl Tacoma TRD Off Road
    Lift kit & 285/70/R17 KO2
    Hello members! First time user here. My question concerns an inline Hypertech Speedo Calibrator and maybe some tricks or tweaks I may have missed when I insalled it in my 2016 Tacoma TRD Off Road. The stock tires were 265/70/R16 and now I am running 285/70/R17. I installed the calibrator acording to instructions and found there was almost a 5 mph differencet in actual speed and speedo diaplaym (display is slower). I checked the speedometer gps against my friends 2014 F150 and there was approx 1 mph and less difference between app reading and the F150 reading. What is going on with my Hypertech unit and what, if anything, am I doing incorrectly?
  2. Jan 6, 2019 at 9:12 AM
    TWTaco
    TWTaco Well-Known Member
    Dave
    Try contacting Hypertech, or search here for it . There is a specific way to calibrate. I just dont recall what it was. something about just adding the true tire size and not anything about gearing. Its on here.
  3. Jan 6, 2019 at 9:17 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Use the actual tire sizes in inches.
  4. Jan 6, 2019 at 9:22 AM
    Idaman
    Idaman [OP] Member
    Jim
    I sent a message to Hypertech and waiting on reply. Meanwhile, I contacted a different supplier than who I purchased the unit and the rep said to play around with the diameters of the stock tires and see what happens. I did bur haven't tested it yet. Thanks for your help. I need all I can get!​
  5. Jan 6, 2019 at 9:29 AM
    Idaman
    Idaman [OP] Member
    Jim
    I did use actual tire size in inches. Nothing changed.
  6. Jan 6, 2019 at 9:31 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    What values did you use. Are you using the diameter of the actual tires or..?
    What tires do you have now.
  7. Jan 6, 2019 at 9:40 AM
    Idaman
    Idaman [OP] Member
    Jim
    I used the actual diameter of the stock tires (30.61) and the present tires: 285/70/R17 (32.71)
