Hypertech Speedometer Calibrator w/6-speed and regear??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deeezy, Nov 15, 2015.
  1. Nov 15, 2015 at 9:34 PM
    deeezy
    deeezy [OP] Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Has anyone with a 6 speed installed this Hypertech speedo calibrator with a regear? I am contemplating buying this but want to make sure it's been successfully installed with larger tires plus a regear. I know it works on an auto but the auto is only effected by the larger tires and not the regearing IIRC. My 6-speed's speedo got thrown off with the larger tires and then again after I installed 4.56 gearing.
  2. Nov 22, 2015 at 6:52 AM
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    Curious as to how big of a tire you went to? I am also looking at regearing and doing a speedo calibration. I dont see an issue with the hypertech speedo calibrator but if your worried I would just call their customer service to make sure.
  3. Nov 22, 2015 at 9:36 AM
    deeezy
    Dana
    Hawaii
    I went to 315/75/16's and regeared to 4.56. Hypertech confirmed that it'll work with a 6-speed so I'm going to give it a try.
  4. Dec 1, 2015 at 12:27 PM
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    Did it work? Does this thing stay hooked up to your old port or does it go on reset the computer and then it comes off?
  5. Dec 1, 2015 at 12:41 PM
    deeezy
    Dana
    Hawaii
    A good deal came up locally for a skid plate and I bought that instead for now. I still plan on picking up this calibrator as a Christmas present to myself and will update this thread after I install. The armor was a little more important than the calibrator.
    JohnNP[QUOTED] likes this.
  6. Mar 22, 2024 at 11:22 AM
    TacoTuesday1
    FL
    Is $250 hypertech the only option for this? Researching to confirm, so far it seems so
    had 35’s, I believe Speedo ran too high
    And now after 4.88 (manual) it’s too low like 10mph under making driving kinda nuts
    Well it’s doable but would like to be able to see without having to use GPS what the speed and RPM actually is.
    seems a bit overgeared like 4.56 might have been a better choice but it’s too late for that now…
    It would be nice if speed was determined by ABS sensor but that seems not to be the case given the above results. I’ve heard manual determines speed differently including a sensor within the gearbox.
    hypertech has a cheaper one $150 but according to the internet it’s a different part number $250 for 05-11 (truck is 08)
  7. Mar 23, 2024 at 6:02 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Zombie Thread...
    I put a hypertech in my 6MT truck. I've not regeared yet though. works great.
    I've corrected speedos in my old '94 pickup by changing t-case gears, and in my old jeep the same way. I did a bunch of research and it was apparent that the only way was Hypertech for the 6MT.
    I'd love for someone else to chime and and say there is a cheaper option though, but I did not find one.
