Hypothesis... OME suspension should have top plate spacers
Discussion in 'Suspension' started by DevL, Aug 3, 2012.
  1. Aug 3, 2012 at 3:04 PM
    DevL
    DevL [OP] Well-Known Member
    So in looking closer at my OME front shock lengths it appears pretty obvious they are designed to be run with top plate spacers to give longer collapsed and compressed length. They are short enough to severely limit droop and have enough room to run a 1/2" top plate without blinking.
    Thoughts?
  2. Aug 3, 2012 at 3:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If that were the case then OME would offer top plate spacers , which they do not
  3. Aug 3, 2012 at 3:45 PM
    DevL
    Then why are OME shocks so short? With a 1/2" top plate spacer they appear to still be shorter than stock, fully extended. Seems like they have been selling the wrong shock to 2nd gen Tacoma owners for years.
    The collapsed length is over an inch shorter than stock. But we cant collapse that last inch due to bump stops.
    The extended length is .8" shorter than stock.
    So even a 1/2" top plate spacer does not give back all our lost trvel.
    I feel like I have been cheated.
    My OME rears give more down travel by 1" and collapse .1" more. That is a good shock. It looks like any Tacoma with an OME front shock is a short travel truck... a truck with less wheel travel because our down travel is shock limited... by like an inch and a half.
  4. Aug 3, 2012 at 3:48 PM
    ffemt2987
    ffemt2987 Shut up Hippie!
    Austin
    Golden
    Cement 3rd gen that was supposed to stay stock
    Rack, sliders, softopper, tjm bumper, eibach temp suspension
  5. Aug 3, 2012 at 3:54 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    won't a 1/2" spacer give you 1" more and then actually be .2" longer then stock? ................................ LT baby :D
    Maybe that's why I always thought they were a very jolting ride in trails with whoops and pot holes. hmmmmmm I'm guessing you have ARB's stated travel #'s?
  6. Aug 3, 2012 at 3:54 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You are comparing fully assembled strut units right? Do you have the N140S or the 90000 shocks?
  7. Aug 3, 2012 at 3:55 PM
    KenLyns
    Belly of the Beast
    Got a side by side photo? Like this:
  8. Aug 3, 2012 at 4:04 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    A top plate spacer won't give the shock any more travel. The fact that you hit the bump stops before the shock is bottomed out is a good thing. If you bottomed out the shock before you hit the bumps, you'd break the shock.
    You're right about the downtravel thing, that seems kind of silly.
  9. Aug 3, 2012 at 4:05 PM
    XXXX
    sKiP
    05 Prius
    If they have an extended 1" up travel and he put on 1/2" spacer it would be the same as stock while getting back the down travel......no?
  10. Aug 3, 2012 at 4:07 PM
    Pugga
    Massachusetts
    I agree. I was just talking about the shock itself just in case someone was reading this and took it out of context. I see what DevL is saying about the bump stops robbing you of travel because of the shock's geometry.
  11. Aug 3, 2012 at 4:10 PM
    XXXX
    sKiP
    05 Prius
    could always go aftermarket bump stops. there are about a zillion to choose from.
    I wanna see links to real numbers dam it :D
  12. Aug 3, 2012 at 4:20 PM
    Pugga
    Massachusetts
    x2. I want to see full droop numbers from hub to fender from someone with an OME lift vs. stock vs. 5100's all without top plates.
  13. Aug 3, 2012 at 6:14 PM
    OZ-T
    Peter North
    British Columbia
    Riddle me this :
    If the OME shocks were " designed " to be used with 1/2" top plate spacers , where are the OME top plate spacers ?
  14. Aug 3, 2012 at 6:40 PM
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
  15. Aug 3, 2012 at 6:41 PM
    Pugga
    Massachusetts
    That's why it's a hypothesis... :rolleyes:
  16. Aug 3, 2012 at 6:46 PM
    KenLyns
    Belly of the Beast
    Just want to make sure this is an apples-to-apples comparison. The length is not from the threaded tip of the shock shaft I hope?
  17. Aug 3, 2012 at 6:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The OME shocks I had were a bit longer than the 5100's.....I had the N140s shocks.
  18. Aug 3, 2012 at 6:49 PM
    canoeski
    canoeski Well-Known Member
    Bill
    Southcentral Wisc
    2012 Tacoma AccessCab
    Debadged. ARE Topper. Tailgate mods, including locking handle. BAMF LCA skids.
    sub'd, since I'm planning on these in the next 4-12 months.
  19. Aug 3, 2012 at 7:01 PM
    DevL
    I have N140S I have started a shock info thread halfway down the suspension page with shock info from the famnufacturers. Please add to it and correct any mistakes. My OME data is from OME's pdf on shock data on the arb website.
    Also the doubling of height vs length does not change the fact the 1/2" spacer essentially lengthens the collapsed and extended LENGTH of the assembled unit. Ride height changes by double but I dont see how a 1/2" spacer chages the shock length more than 1/2"
    If my factory specs are wrong then my hypothesis is wrong. Please go look at my other thread.
  20. Aug 3, 2012 at 7:07 PM
    OZ-T
    Peter North
    British Columbia
    How about a link to the ARB shock info pdf ?
