Hypothetical - 2.7 AWD conversion considerations (xpost from technical)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barnburner, Oct 21, 2017.
  1. Oct 21, 2017 at 7:24 AM
    Barnburner
    Barnburner [OP] Well-Known Member
    2015 Tacoma SR
    TL;DR:
    Coming from the Audi/Quattro world and reading that the Manual FJ Cruiser's have a Torsen based AWD setup got (forgive the pun) my wheels turning. Would swapping in a Manual FJ Cruiser transfer case and carrier front axel get me full time AWD? And should such a swap be relatively easy on an already 4x4 truck?
    Quattro goodness for kicks:
    The long version:
    My taco's a manual 2.7 4x4, but most of my research so far has turned up info on the 6 speeds/v6's. I'm trying to minimize my assumptions so I still have some things I am wondering about:
    1. Do both R155F & RA60F transmissions have the same T-case bolt pattern? (based on what I've read, I'm thinking this is the case)
    2. If the bolt pattern is the same, the next piece would be matching the Manual FJ T-case input shafts to the 5 speed transmission (with the R155F having a different number of splines), right?
    3. If the T-Case can be swapped in, the rear driveshaft would need to be shortened to accommodate the T-case's longer length. Would the front drive shaft need adjustment too?
    Then this is where it really starts to get murky for me. Keeping the stock ADD system, and pending the electronics are working correctly, is this feasible?
    • 2wd (Front axles disengaged via ADD, center diff locked and sends all power to the rear)
    • AWD (Front axles engaged, center diff sends power to front and rear, modulating in real time based on conditions)
    • 4WD (Front axles engaged, center diff locked to split power 50/50 front and rear)
    This would essentially keep 2wd, add AWD, keep 4High and remove 4Lo. (for simplicity, ADD could be removed altogether by swapping in the FJ front dif/axle carrier, removing 2wd and just keeping AWD and 4Hi) What electronic considerations are at play here? (controllers, ecu's, traction control systems etc)
    Bonus: Am I totally nuts for rethinking a setup in an already pretty capable truck?
    Here is why it's appealing to me in the first place:
    • my truck is a daily driver. 98% of the time, it will only see street use. This does include snow though, and Quattro saved my butt many a time in the past.
    • I will very seldom use 4Lo.
    • 2wd for good conditions preserves my gas milage, while AWD for intermittent/bad conditions (like driving on partly snowy/icy pavement) prevents the need to constantly toggle into 4Hi.
    What do you guys think?
    PapaBear likes this.
  2. Oct 21, 2017 at 8:29 AM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    If your swapping in a fj manual cas why would you lose low range? Those cases have awd, 4wd h, 4wd l......
    DanoDavis likes this.
  3. Oct 21, 2017 at 8:32 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You would need A LOT more than just a tcase and diff
    -tcase
    -front diff
    -front/ rear driveshafts
    -transmission
    -hubs/wheel bearings
    -cv axles
    If you can get a good deal on these parts then go for it
  4. Oct 21, 2017 at 8:35 AM
    crolison
    Ar vah da, CO
    POS
    You wouldn't need front diff, cv's, or hubs, wheel bearings.
    The only thing different from an add fj/tacoma and awd fj front end is that it doesn't have an add tube, it has a straight direct pass through tube with no disconnect to the passenger cv axle.
    05Taco4x4 likes this.
  5. Oct 21, 2017 at 8:41 AM
    anthony250f
    Anthony
    San Diego, CA
    Is his truck already 4wd..?
  6. Oct 21, 2017 at 8:45 AM
    crolison
    Ar vah da, CO
    POS
    He mentions keeping the stock add system....... and is asking if his transmission t case pattern is the same as the fj's trans t case pattern
    Also he talks about owning an Audi, and commuting in the snow....
  7. Oct 21, 2017 at 10:20 AM
    Barnburner
    2015 Tacoma SR
    Ha yes, I should have specified. It already is 4wd.
  8. Oct 21, 2017 at 10:23 AM
    Barnburner
    2015 Tacoma SR
    I should clarify. I don't think I would loose 4Lo knowing that the FJ's have 4Lo too, I just wouldn't have a need for it. Just thinking of ways to keep 2wd, have AWD, and then 4Hi (with the center diff locked)
  9. Oct 21, 2017 at 10:57 AM
    crolison
    Ar vah da, CO
    POS
    Well you should be hypothetically able to manually lock the and manual lock the center diff.
    Your front driveshaft will always be putting power towards the front diff though
  10. Oct 21, 2017 at 11:03 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    hmmm nvm
    op check out rock solid toys, they have messed with the fj case a good bit
  11. Oct 21, 2017 at 11:04 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Why go through all of the trouble of converting to awd and want 2wd? Afaik, on most awd setups, the rear wheels do more work than the front (60/40).
  12. Oct 21, 2017 at 12:54 PM
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    Weren't there some 3rd Gen 4Runner models that had full time 4WD as well, with just a hi and lo select? Maybe I'm crazy, but I swear I test drove one in 2002 or 2003 that was like that. Maybe if a swap IS possible, that would work too.
    GreyBaldTaco and Torspd like this.
  13. Oct 21, 2017 at 2:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yes you can get awd fj's and 4runners.... the tcase has a center diff with a locking option. The only place that they will be better in is on something like a snowy icy road. But driving selectable 4wd NON AWD trucks forever and i can tell you it aint worth the hassle to put the awd tcase in.... more shit to go wrong, more complexity for very very little gains.
  14. Oct 21, 2017 at 3:59 PM
    Barnburner
    2015 Tacoma SR
    I know with most Audi's (non S/RS variants) have a pretty modest split, and only hit that rear bias under some conditions. For the most part, they stay around 50/50. If popping back into 2wd is even possible, it would just be a perk of maybe a few more MPGs.
  15. Oct 21, 2017 at 4:20 PM
    replica9000
    2019 T4R ORP
    Off of the top of my head, I can't think of any vehicles that are awd that can be put into 2wd only. Maybe you want something that can be full time 4wd instead, especially if you're used to 50/50 bias.
    Edit: if this is all about needing better traction on snowy roads, perhaps look into a good set of AT tires if you're still running stock tires. Can make a huge difference.
  16. Oct 21, 2017 at 4:37 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You will find a lot of ppl naysay projects like this. I say go for it. I think you generally have the tech concepts nailed down.
    not_nick, tinker_troy, jmaack and 6 others like this.
  17. Oct 21, 2017 at 4:42 PM
    replica9000
    2019 T4R ORP
    I'm not trying to sound like a naysayer. Just mentioning alternatives. @HomerTaco has an FJ transfer case in his truck. He might be able to help.
  18. Oct 21, 2017 at 4:50 PM
    jowybyo
    Joe
    Baltimore, MD
    Sorry, that wasn't a comment directed at anyone. More just words of wisdom/encouragement to the OP.
  19. Oct 21, 2017 at 4:51 PM
    nd4spdbh
    SoCal
    There are two styles of FJ cases (maybe even 3)..... but i know there are at least 2. 1. is the one everyone wants cus they can do a twin stick manual setup.... 2. is the one no one wants which is the awd one with a diff in the tcase.
    FYI, if you did keep ADD in the front with the AWD case you would have to figure out how to lock the center diff if you switched the front axle add to disengage otherwise you would go nowhere in"2wd".... but it would be pointless as you would still be spinning the front driveshaft and diff. AFAIK there is no way to drive just the rear output on the AWD tcase.
  20. Oct 21, 2017 at 5:00 PM
    anthony250f
    Anthony
    San Diego, CA
    Ain’t got time to read the entire post....cliff notes plz
