Hypothetical - 2.7 AWD conversion considerations (xpost from technical)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barnburner, Oct 21, 2017.
  1. Oct 21, 2017 at 5:02 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Yup. Great point.
  2. Oct 21, 2017 at 5:04 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    @HomerTaco has the twin stick version, but maybe his research into the FJ drivetrain itself might be useful.
  3. Oct 21, 2017 at 6:58 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You rang?
    replica9000 likes this.
  4. Oct 21, 2017 at 7:12 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Not sure of the current specs of the op's truck.
    There are two FJ cases - the one out of an auto trans which is the same size as the Tacoma case and the only difference is it has a manual shifter. This comes stock with a J shift and most folks will separate them into having two separate shifters, hence "twin-stick". This allows for the option of selecting 2 low and eliminates the electric shift motor.
    Then there's the one out of the manual transmission FJ which is full time 4wd. This unit is also quite larger.
    The manual transmission FJ does not have the ADD in the front diff - it is a straight tube and it is always engaged.
    This is interchangeable with the add in the taco and essentially keeps the front axles engaged all the time and illuminates an electric motor that unfortunately for some has failed.
    I have to direct you to @Torspd to discuss AWD on the taco. My experience is just with adding the FJ case and a crawlbox for low low range. :D
  5. Oct 21, 2017 at 7:17 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Barnburner[OP] likes this.
  6. Oct 21, 2017 at 7:28 PM
    replica9000
    2019 T4R ORP
    Might help the OP. At the moment, I'm content with my stock t-case. I had looked into maybe tricking the truck into engaging 4-lo, without actually engaging the front wheels to basically get 2-lo. But I guess it's not possible, which led me to follow what you did.
  7. Oct 21, 2017 at 7:32 PM
    jowybyo
    Joe
    Baltimore, MD
    It's possible.
  8. Oct 21, 2017 at 7:32 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    2 low is really just a novelty. The real win is compound low - especially with the manual trans. However, with the actuator motors failing the mod eliminates that possibility which is also a win.
  9. Oct 21, 2017 at 7:39 PM
    replica9000
    2019 T4R ORP
    Links? Last time I looked into it, no one had a solution.
    If it matters, I don't have any traction aids.
  10. Oct 21, 2017 at 10:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How resourceful are you? How much time do you have? What is the depth of your budget? How badly do you want to complete the project?
  11. Oct 22, 2017 at 5:20 AM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    4Runner transfer case gives you 4Hi and 4Lo with an unlock center differential, this is the same as a AWD. You can lock center differential an then have 4WD.
    YamaDirtrider and Barnburner[OP] like this.
  12. Oct 22, 2017 at 6:29 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    It’s a cool concept, and something that would be useful to those like me in snowy climates. I’ve had AWD vehicles most of my driving life, WRX, CRV and now 4x4. I can say that having full time AWD was great but not needed most of the time, with 4x4 when it gets back I turn a button and have traction. I hope you complete this mod if it’s something you wanna do, but it seems like the gains would be negligible.
    libagui and Barnburner[OP] like this.
  13. Oct 22, 2017 at 6:36 AM
    replica9000
    2019 T4R ORP
    How is the AWD on the T4R and FJ on gas compared to 4WD on our tacos?
  14. Oct 22, 2017 at 6:41 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    we have an AWD FJ and consistently get 16mpg
  15. Oct 22, 2017 at 6:44 AM
    #35
    replica9000
    2019 T4R ORP
    I think my Taco gets 10mpg when in 4wd.
    BassAckwards[QUOTED] likes this.
  16. Oct 22, 2017 at 6:45 AM
    #36
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    My wife’s forester gets 34+ and it’s AWD.
  17. Oct 22, 2017 at 7:55 AM
    #37
    Barnburner
    Barnburner [OP] Well-Known Member
    2015 Tacoma SR
    Dudes, thanks for the info! I'll dig into the 4Runner transfer cases a bit more. I should also check and see if either the FJ's or 4Runner's rear driveshaft would work, vs getting the Tacoma's shortened.
    It seems like the basics would work:
    • FJ/4Runner T-case,
    • Shortened rear driveshaft (or maybe FJ/4Runner driveshaft?), and
    • FJ/4Runner Front diff/Carrier axle
    would net me AWD, 4Hi and 4Lo (Courtesy of the FJ/4Runner locked center diff)
    More tricky would be
    • Shortened rear driveshaft, and
    • Stock Front diff/Carrier axle with ADD system
    would net me AWD, 4Hi, keep 4Lo, and potentially keep 2wd. (Courtesy of the ADD and manually locking the center diff at the same time)
    Technically less to swap, but the electronics of all of it, that's another conversation...
    Good questions to ask!
    I'm pretty resourceful, and plan/research nearly every side of something before I dive in. Timing wise, this is more of a brain exercise than anything else. I still have the Audi (affectionately known as Tammy2, hence the avatar) waiting in the garage pending an engine swap, and taking priority over this "project". Budget is something I'm always keeping a pulse on, but I'm not naive in understanding the costs of doing something correctly. If the project never happens, I won't be heartbroken. But the idea of a "Quattro Taco" is something that is really appealing to me.
    Torspd[QUOTED] likes this.
  18. Oct 22, 2017 at 8:12 AM
    #38
    Pigpen
    Dan
    Northwest Montana
    I have 2wd low range. There's a DIY version and a plug and play version, made by @Up2NoGood
    I have the plug and play version and couldn't be happier. $250, ten minute install, 100% reversible, no more roasting your clutch backing up your trailer, no more fearing the destruction of your CVs when you need low range in high traction surfaces while backing up said trailer.
  19. Oct 22, 2017 at 8:24 AM
    #39
    Barnburner
    2015 Tacoma SR
    Thanks man. Part of this whole thing is deciding on the level of benefit I'd get. Snow is front of mind, but so is traction in the rain and general driving dynamics. (As was rightly mentioned earlier, I know a solid set if tires go a long way). Obviously the Tacoma will never handle like the Audi on twisty backroads, but there is something to be said for not spinning tires or sliding out around town when it's a little slick out.
    not_nick likes this.
  20. Oct 22, 2017 at 10:17 AM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I feel that I am lacking some knowledge, so could someone inform us how to mate an FJ or T4R transmission to a 2.7L 2TR?
    That being said, are there already foreign models which have AWD mated to the 2TR? Such as the Prado perhaps?
