I’m an idiot: Front Lug Stud Broke off. Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ddanjeong, Jul 3, 2021.
  1. Jul 3, 2021 at 3:23 PM
    ddanjeong
    ddanjeong [OP] Well-Known Member
    Dan
    19 OffRoad Double Cab
    265/75r16 General Grabber AT/X Diode Dynamics SS3 Sport Fogs / Ditch Lights UpTop Overland Bravo Roof Rack
    Well, I over tightened my lug nut while doing my rotation at 90ft pounds and it just snapped right off. I was so pissed off lmao.
    Now that I’ve cooled down, I ordered the parts to replace them my self.
    Someone please tell me if my understanding is correct:
    Pop tire off and remove brake assembly and take off the rotor.
    punch out the broken stuff with a punch rod and insert the new stud.
    I bought a stud installer tool but I feel like there’s not going to be enough room to clear the inner lip on the hub. We will see.. in case that doesn’t work I plan on using layers of washers to tighten it in.
    Is there something I’m missing or is that pretty much it??
    Thanks… I feel pretty stupid by the way for doing this haha.
  2. Jul 3, 2021 at 3:25 PM
    ddanjeong
    Dan
    Also, I plan on not driving untill fixed but in case I have to… I should be safe correct?
    wilcam47 likes this.
  3. Jul 3, 2021 at 3:27 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Yeah you'll be "fine" driving around. Pretty straight forward to replace. Make sure you don't over install the stud. You should be able to see and feel when it is in, pretty hard to do but just beware. Depending on what kind of stud installer you bought you should clear the hub lip.
    P.S. How in gods name did you tighten that thing so tight?! Next time I would recommend a few less Ugga Duggas sir.
  4. Jul 3, 2021 at 3:29 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I drive on 5 when I take off my locking lugnuts for dealer service stuff. I haven't lost a wheel yet!
    Tundra only has 5...
    tcjacado, Vlady, philth and 3 others like this.
  5. Jul 3, 2021 at 3:33 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Someone has already probably over torqued the crap out of it before you. You were just the final straw. I think the spec is 83 ft/lb so you should not have snapped it if it was not already under duress. You should be fine until you replace it.
  6. Jul 3, 2021 at 3:33 PM
    Lt. Dangle
    Ohio
    It's really easy, I have done it to one in the rear using a torque wrench. If you cross thread it, it will snap off at a very low torque as well.
    ndoldman59 and ddanjeong[OP] like this.
  7. Jul 3, 2021 at 3:34 PM
    Mastiffsrule
    Scott
    True, happened with I girl I know.
    jmauvais, tcjacado, NoOne and 3 others like this.
  8. Jul 3, 2021 at 3:35 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  9. Jul 3, 2021 at 3:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  10. Jul 3, 2021 at 3:47 PM
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    LMAO @ this thread..
    philth and ddanjeong[OP] like this.
  11. Jul 3, 2021 at 3:52 PM
    Mastiffsrule
    Scott
  12. Jul 3, 2021 at 3:54 PM
    ddanjeong
    Dan
    Thanks everyone who responded. Read them all. Yes, I feel dumb. Maybe I was the last straw and the tire shop guy over tightened it before. Regardless…
    the stud installer tool I bought is :Lisle 22800 Wheel Stud Installer https://www.amazon.com/dp/B000ETUD22/ref=cm_sw_r_cp_api_glt_fabc_GD0K7VBTFVP3ZNDHQYB1
    the studs I bought are the OEM: Genuine OEM Toyota Lexus New Wheel Lug Stud - Set Of 2-90942-02049 https://www.amazon.com/dp/B07997HQFF/ref=cm_sw_r_cp_api_glt_fabc_39WB6YS2N01MRKC3DDDT
    Can someone verify those because my stupidity is on point today. Thanks
    ORtoCOTaco likes this.
  13. Jul 3, 2021 at 3:58 PM
    Grossomotto
    2017 4WDV6LB6MT
    On a scale of 1 to 10 this is about 2. Everyone in here has done something dumbererer.
    Chew, MOC221_, tcjacado and 4 others like this.
  14. Jul 3, 2021 at 4:01 PM
    Mastiffsrule
    Scott
    Don’t feel dumb, if this is the worse thing going on right now, uRaOK. :bowdown:
  15. Jul 3, 2021 at 4:05 PM
    Grossomotto
    2017 4WDV6LB6MT
    Way back in the day I was pulling maintenance on a fleet of trucks (what company lets a 16 year old kid do this?). Well, I put antifreeze in all the windshield wiper fluids. Fun fact, they're both blue.
    Lt. Dangle, ORtoCOTaco and AJKlug1 like this.
  16. Jul 3, 2021 at 4:24 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  17. Jul 3, 2021 at 4:27 PM
    Grossomotto
    2017 4WDV6LB6MT
    They should be glad I never changed the oil
  18. Jul 3, 2021 at 4:40 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I hope this was the first one tightened, otherwise i'd be worried the others will break
    Chew likes this.
  19. Jul 3, 2021 at 4:49 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    90 shouldn’t have snapped that off. Torque wrenches are not very accurate unless you buy the really expensive ones so a wrench set at 83 could be 80 or 85 easily. When I was working part of my job was calibration control and we threw away a lot of wrenches that were out of spec. Also, it’s important to back off the wrench to zero to reduce the chances of stretching the spring.
  20. Jul 3, 2021 at 4:51 PM
    MIDTNTACO
    Middle Tennessee
    Steves104x4 likes this.
