I’m bored and need ideas.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mwrood, Mar 5, 2021.
  1. Mar 30, 2021 at 11:59 AM
    #121
    mwrood
    mwrood [OP] Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    For sure! I have an iPhone 12 and only like an 1/8” is covering the vent. Doesn’t have any effect on airflow or anything. I agree though; blocking the vent is a horrible choice. :)
  2. Mar 30, 2021 at 3:50 PM
    #122
    TRDRivalFox
    TRDRivalFox Well-Known Member
    SoCal
    2021 Cement Tacoma TRD OR
    SCS Blaze10 17'' / BFG K02 / Eibach Stage 1 Pro Lift
    Looking at doing an instal for a sub and amp also, was yours pretty easy to instal? Any tips and reccomendations on the instal or sound quality of that combo? Were you pleased with the overall result?
    Found this video for doing the wiring and instal and Id imagine this is what you did also?
    https://www.youtube.com/watch?v=ZrhT2___eAk
  3. Mar 30, 2021 at 5:28 PM
    #123
    mwrood
    That’s the general idea I followed except my setup was different bc I had factory JBL. Overall I was not impressed with the stock JBL bass. It was “ok” while not moving but as soon as the truck was in motion the road noise drowned out the bass. There’s also factory related things in the amp that keep the bass from unceasing once the volume goes to a certain point (I don’t know the terminology or specifics on it...I just wasn’t pleased).
    When I did my install I swapped out the door and dash speakers as well. Kicker KS components up front and kicker KS in the rear. The sub I used was an 8” Kicker CompRT. Amp is a Kicker CS 660.5. Since I was wanting to do away with the factory JBL amp I used the Rockford Fosgate DSR1 which acts like the stock amp (typing everything together) but also includes a DSP. Then the Marstro ATO3 harness to keep every plug and play.
    I like to try and keep things as plug and play as possible and this set up allowed for that. Only additional thing I had to do was run power to the battery and ground into the chassis.
    I also put sound deadening on the doors when I was replacing the speakers, and along the back wall. This helps out greatly and I would definitely recommend it if you’re doing anything aftermarket stereo related.
    Other than that, I had my sub box and amp rack made by MrMarv (if you search the forum you’ll get a ton of results and his contact info). You tell him the setup you’re using and he builds the box in spec for your sub.
    Overall I’m happy with it. If the bass was about 10% more it would be excellent. But, it’s still 10 times better than the stock. I only out an 8” in and it’s only got 300 watts going to it; I knew I wasn’t going to blow any windows out so I was not really “under impressed” or disappointed. With that said, it’s perfectly fine for what I wanted to accomplish.
  4. Mar 30, 2021 at 6:10 PM
    #124
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Add a catback exhaust. No real performance gains but it’s plug and play and only requires minimal mechanical know-how and a little elbow grease. Like I said, there are no real performance gains, but it’ll sound like it!
    mwrood[OP] likes this.
  5. May 21, 2021 at 4:12 PM
    #125
    Jpalnud93
    Jpalnud93 New Member
    Josh
    2020 sport quicksand
    What did you use for the TSS logo tint? I love the look of the black grill with the tinted emblem!
    Also what raptor lights and harness did you get?[/QUOTE]
  6. May 22, 2021 at 6:49 AM
    #126
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
    Overhead Molle panel!
    Here is mine installed. As of this posting, both models still show in stock.
    46EA1F8D-3875-45CD-85B9-E51E17C26ED0.jpg F39441BB-32BA-4974-9544-23BB164FB249.jpg
  7. May 22, 2021 at 6:54 AM
    #127
    NW-Taco
    NW-Taco Well-Known Member
    Josh
    Oregon City
    2020 Ram Power wagon
    Had to sell my 17 Tacoma for a tow rig in order to pull my new home. Still here for a bit to keep in touch.
    Decked bed drawer system. I love mine!
    Goatfrog likes this.
  8. May 23, 2021 at 1:26 PM
    #128
    flacoloco
    flacoloco Well-Known Member
    question about the decked system. Does it improve the ride quality since there is more "stable" weight in the back of the truck?
  9. May 23, 2021 at 1:49 PM
    #129
    NW-Taco
    Josh
    Oregon City
    It weights 250 pounds empty. So it would defiantly help keep the rear end down. Loaded up with gear it will sag the rear end. I added a Helwig helper spring. But I run fully stocked all the time and hated the saggy bro lean.
    flacoloco[QUOTED] likes this.
