I’m really saggin
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Col4bin, Aug 25, 2020.
  1. Aug 25, 2020 at 7:56 PM
    Col4bin
    Col4bin [OP] Well-Known Member
    Maine
    2018 TRD OR Double Cab
    My stock suspension TRDOR long bed is really saggin in the rear. Back there is my Leer topper. Passenger side rail
    Mount has my high lift and 4 Maxtrax and the drivers side an axe and shovel. Also running an arb rear summit bumper.
    I’m sagging low and leaning to the passanger side.
    No plan for a lift, but wondering if an add a leaf would correct this issue or if I should consider something else.
    TIA TW!
  2. Aug 25, 2020 at 7:59 PM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Probably want to swap out your leafs for a heavier duty. As the add a leaf will sag.
  3. Aug 25, 2020 at 7:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Add a leaf for sure, the extra weight will fatigue the springs quickly and eventually break pre maturely.
    Your truck is young enough that the pack in the rear still has lots of life, so I would start with an AAL and go from there.
    Col4bin[OP] likes this.
  4. Aug 25, 2020 at 8:01 PM
    Shellshock
    Iowa
    I'd swap the leaf pack.
    I've got ICON RXT leafs and i've been very happy with it. Replacing the pack is pretty easy
  5. Aug 25, 2020 at 8:03 PM
    AntMan408
    Bay Area, CA
    Or call Marie at @HeadStrong Off-Road and tell her your needs and she’ll point you in the right direction.
    YF_Ryan, b3itz and Clearwater Bill like this.
  6. Aug 25, 2020 at 8:05 PM
    Col4bin
    Maine
    This is great intel. Is going HD springs or AAL possible without a lift?
  7. Aug 25, 2020 at 8:07 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    U will still be lopsided
    predominant driver sags left front
    U could try balancing Ur weight diagonally...........truck has more bias left side weight from factory
    U could try AIR bags As U can differentiate side to side
  8. Aug 25, 2020 at 8:07 PM
    Shellshock
    Iowa
    you just need to total up your weight and you can get the springs to compensate. You might end up slightly higher but not more than an inch or two.
    YF_Ryan and Col4bin[QUOTED][OP] like this.
  9. Aug 25, 2020 at 8:09 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
  10. Aug 25, 2020 at 8:10 PM
    Col4bin
    Maine
    and be ok to not touch the front at all?
  11. Aug 25, 2020 at 8:10 PM
    Shellshock
    Iowa
    yup.
    Col4bin[QUOTED][OP] likes this.
  12. Aug 25, 2020 at 8:12 PM
    Oregon TRD Off~Road
    Oregon TRD Off~Road Well-Known Member
    Kent
    2017 Tacoma TDR off-road
    You could also just add airbags in the rear. It would level it up and give you good support until you choose a lift.
    Big tall dave and Thegenerik1 like this.
  13. Aug 25, 2020 at 8:14 PM
    Bishop84
    But then you have to decide if you want to add on board air or check the pressure often.
    I also found air ride to be jarring when over 30psi. I find its good for leveling when loaded, but for full time load, springs are the answer.
  14. Aug 25, 2020 at 8:16 PM
    ROAD DOG
    FEW
    no need for on board air
    i tow heavy
    never used more than 9psi to level otherwise Ur NOT payin attention to tongue weight
    Thegenerik1 likes this.
  15. Aug 26, 2020 at 12:08 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    Add a leaf is just a bandaid. Poor one at that. If you do anything go full leaf pack. Probably close to or over payload already with your accessories.
    Aaronparker001 likes this.
  16. Aug 26, 2020 at 12:26 AM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    +1 for this
  17. Aug 26, 2020 at 4:24 AM
    Aaronparker001
    Aaronparker001 Just another basic dude in a tacoma
    Pacific Northwest
    2019 TRDOR DCSB MT BLACK
    This sucks that this happens on our trucks but the rear leaf springs leave a lot to be desired. I went with the AAL and have regretted it since. Like people before me have commented, it’s a bandaid at best.
    Buy once, cry once.
  18. Aug 26, 2020 at 4:29 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    So you never upgraded your suspension with the topper ?? It’s a good idea to do suspension all the way around prior to a topper due to weight . The stock setup is not designed for long term weight . I would do a full suspension at this point not just the rear .
    BalutTaco likes this.
  19. Aug 26, 2020 at 5:28 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I have a LB with a heavy ARE cap and some permanent weight in the bed in a lockable plastic bin. I added Sumo Springs 612-40s and am happy with them. Normally they are off the frame, but with my added weight they are touching and it raised it up enough to have 1/2" of rake. I like how they ride and firm up the feel when turning etc. Eventually I'll probably do a lift and add heavier leaf springs, but for now it seemed like a decent cost effective and durable solution.
    Taco16LB and Col4bin[OP] like this.
  20. Aug 26, 2020 at 8:03 AM
    Col4bin
    Maine
    Correct, I have not touched the suspension at all. Started to do all of the math and noticed the sag, hence my post. Trying to learn my options here.
