I’m swamped
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skubbasteve, May 28, 2025.
  1. May 28, 2025 at 12:54 PM
    Skubbasteve
    Skubbasteve [OP] Member
    2012 Super White Tacoma 2WD
    I just got my Tacoma wheel balanced and it’s makes buzzing/ vibrating as I accelerate the throttle to certain speeds.Any suggestions brothers and sisters of Tacoma world. Greatly appreciated
  2. May 28, 2025 at 12:58 PM
    RockinU
    RockinU Well-Known Member
    Texas
    If it wasn’t doing it before, take it back and get it re-balanced…
    Sprig likes this.
  3. May 28, 2025 at 12:59 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Rotate wheels to see if the noise moves. Investigate hub bearings if it doesn't.
    O'DubhGhaill likes this.
  4. May 28, 2025 at 1:12 PM
    Skubbasteve
    Rock Lobster: The bearings are good checked them last week and no play or no rough grinding sounds
  5. May 28, 2025 at 1:29 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    How did you check them? About a year ago, my car started producing a very gradual howl. It was imperceptible at first, but then it became noticeable, and then it became unbearable. I kept putting the darn thing on jackstands, shaking the wheels, rotating tires back to front, feeling by hand. I even put it in gear and let the wheels free-spin under engine power. Every time I checked it while it was in the air, they were stone quiet. Finally I just bit the bullet and swapped in a set of cheap hubs. And that's what solved it. Bearings are weird like that. They will hum when they start to go bad, but often they will only hum when under load. They have been known to hide their symptoms when the wheel is in the air.
  6. May 28, 2025 at 1:51 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    OP, see post #2. Take it back to the shop that balanced them.
