I’ve been in denial…..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 6host, Aug 16, 2022.
  1. Aug 16, 2022 at 5:27 AM
    6host
    6host [OP] Active Member
    I have to come clean.
    I didn’t believe it.
    I didn’t think it could happen to me.
    I thought all you guys were crazy.
    I have…… Taco Lean……. There I said it. :rofl:
    Haha, ok so I went out and measured my ground to fender and hub to fender heights as I’m planning out my lift. Full tank of gas on level garage floor. 2021 DCSB TRD OR
    Front driver: Ground 35” Hub 20-1/4”
    Front passenger: Ground 35-1/4” Hub 20-1/2”
    Rear driver: Ground 36-3/8” Hub 21-1/2”
    Rear passenger: Ground 36-7/8” Hub 22”
    Its about 1/4” difference in the front and about a 1/2” difference in the rear
  2. Aug 16, 2022 at 6:51 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Oh my! Thats a tragedy!:annoyed:
  3. Aug 16, 2022 at 6:53 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    if you wouldn't have measured you wouldn't have known, BUT now you no and you'll lose sleep over it and worse yet, we all know now too:rofl::rofl:
    6host[OP] likes this.
  4. Aug 16, 2022 at 6:55 AM
    6host
    I know right!?!?!?!
  5. Aug 16, 2022 at 7:01 AM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    LOL,,, just wait till you try to fix it. And you will,,, that's when things will get interesting.:rofl:
    cryptolime and 6host[OP] like this.
  6. Aug 16, 2022 at 7:04 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Put the wife in the truck and re-measure.
  7. Aug 16, 2022 at 7:31 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I have taco lean every time I climb my 300 lb fat butt in!:D If you think that’s bad you should see what Prius lean looks like when I get in my wife’s car.:rofl:
  8. Aug 16, 2022 at 7:33 AM
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    I have to laugh...my Jeep had a lean too. Maybe it's common because all of our fat asses put more wear on the driver's side. :rofl:
  9. Aug 16, 2022 at 7:41 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I thought I was on LinkedIn for a second there.
  10. Aug 16, 2022 at 7:46 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
  11. Aug 16, 2022 at 7:46 AM
    SpeySquatch
    2016 TRD OR DCSB
    thats normal with a full tank of gas. I would ignore it and measure when the tank is close to empty.
    another trick to see how much the gas tank affects the lean when full is look at the back of the truck with the nose pointed downhill when parked on an incline…you will see a much more drastic lean to the driver side…normal
  12. Aug 16, 2022 at 7:53 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Airbags will fix anything.
  13. Aug 16, 2022 at 8:14 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I flop my ballz into the passenger seat to balance my lean but only when I’m solo.
  14. Aug 16, 2022 at 8:27 AM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
  15. Aug 16, 2022 at 8:30 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Could be worse. Could have taco lean to the passenger side but when you put a level on the truck it’s perfectly flat.
  16. Aug 16, 2022 at 8:31 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Well within tolerance, carry on.
  17. Aug 16, 2022 at 10:45 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  18. Aug 17, 2022 at 5:18 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Just remember, de-nile is only a river in Africa :anonymous:
  19. Aug 17, 2022 at 5:26 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Is that not de wey?
  20. Aug 17, 2022 at 5:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I like walmart for a lot of things, but purchasing the end-piece that has a primary function of keeping my ass separated from a 1" aluminum post - is not one of the things I will buy there.
    AxisCab, 6host[OP] and RIX TUX like this.
